2 members (NJC, greenie-reddy),
159
Mod | | | Forums66 Topics128,260 Posts1,058,287 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2004 Posts: 191 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 191 | Well, I'm so close to firing up my SBC I can taste it. Went out to the shop this afternoon to connect the fuel line and break in the cam, but was greeted with a large puddle of transmission fluid on the floor. I had put in 5 qts. in the TH350 yesterday evening. Figure I've lost a couple. What a mess! Anyway, it appears that it is leaking from the speedometer cable connection on the tranny. My cable seems a bit short anyway. I'm running a 79 Z28 front clip and have not been able to connect the speedo in the cab. I'm wondering about just finding another cable that is a tad longer. Any suggestions? Is this something I can find at my FLAPS, or am I going to have to order another cable if I want a longer one? Help! :confused: | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | you should be able to find "universal" cables various lengths at the local, just need to make sure it has the right ends .... I assume you do know the stock speedo won't be accurate ... but it would keep the fluid in anyway Bill | | | | | Joined: May 2004 Posts: 191 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 191 | Red58:
Thanks for the reply. PO said that the speedometer was accurate with the Camaro rearend (3.73 ratio). I assume he changed out the drive gear in the tranny. I reinstalled the same drive gear into the rebuilt tranny I got, so I'm hoping it is at least close. Will check with my FLAPS. | | | | | Joined: Oct 2006 Posts: 119 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 119 | There's always a solution for the speedo: www.gaugeguys.com/ratioadapt.htm | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The cable does not keep the fluid in. There is a small seal in the housing for the stem of the gear & an o-ring around the housing. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
