1 members (klhansen), 161 guests, and 5 robots.
Topics128,089
Posts1,056,140
Members48,436
#1380024 10/08/2020 8:36 PM
1 Offline
Replaced this line twice and both leaked at swivel coupling. Same manufacturer. Any ideas?
Which fuel line are you talking about?
From fuel tank to pump or pump to carburetor?
My suggestion (worked for me) take line to local shop, have them bend/ make a new one. I've had Zero problems with mine. Both "hard" lines I had done.
Todd
1950 Chevy 3100
Hi,
Well that's frustrating. Think you're referring to the short rubber line that connects the petcock valve to the hard line. I ordered one from LMC. No problems with it. Any hose shop would be able to build it too.
1 Offline
Referring to line from fuel tank to pump. I will.check out LMC. Seems that only one company manufactures this fuel line. Thanks guys!
Sir Searchalot
Sir Searchalot
Eliminate all petcocks, swivels and as many connections as possible. Use the least amount of rubber hose as possible and carry hose and clamps with you. Can you post a part number and vendor for the "swivel coupling"?
Can't you bend your own, or go to a nearby repair shop and have them make one? Or is you current line not stable enough to replicate? They have lines now that can be bent by hand and might be worth a try.
Ed
I do like to set mine up the same way they came 70 years ago, but I am done with the aftermarket short, soft line with the swivel. The reason is not the swivel. It is the composition of the rubber which melts from today's 10% ethanol gas formulation.
Yeah, I took mine to our old time NAPA and they bent a new line for me. They even put a small ridge around rubber hose end towards pump. I do not like swivels, bartomas is right on his statement. The best shut off valve is the original type at the tank. Doc.
Sir Searchalot
Sir Searchalot
If I had a 1950 Chevy truck, I would put a pipe plug in the tank outlet hole, Get rid of all that junk down there waiting to leak, waiting to squirt into your eyes, and would buy the sender that sucks out the top. Run metal line down and out. Short piece of rubber to the frame, back to metal tubing down the frame rail, short piece of rubber to fuel pump. Click.
That's a cool guy move. cool
