0 members (), 93 guests, and 1 robot.
Topics128,055
Posts1,055,782
#1380100 10/09/2020 2:22 PM
Going to install a horn relay in my 51. Its marked with the following numbers: 30, 85, 86, 87. Whats the proper makeup for this relay?
1951 Chevy 3100 5-window
261 cu in, 348 Head, Split Fenton Exhaust
Offy with Dual Weber 2 Bbl Carbs
51bowtie #1380102 10/09/2020 2:27 PM
By the way, they are aftermarket modern horns.
51bowtie #1380104 10/09/2020 2:35 PM
What brand & model-number horn?
What brand & model-number relay?
And/or post/attach photos of both.
tclederman #1380111 10/09/2020 2:57 PM
Both are Hella Products. The relay is model 960 388-46. 12v
51bowtie #1380112 10/09/2020 3:04 PM
Here is a typical installation absconded from the googler.
Another quality post.
Real Trucks Rattle
Rusty Rod #1380114 10/09/2020 3:13 PM
Looks like what I need but....the relationship between the 85 terminal and the 30 terminal. Is it saying I need to jumper the two terminals?
51bowtie #1380126 10/09/2020 4:18 PM
Yes, although you could power each one separately from different circuits.
51bowtie #1380159 10/09/2020 8:54 PM
The relay is a Bosch relay. The attached is similar to Rusty Rod's diagram, but shows the internals of the relay.
don
51bowtie #1380166 10/09/2020 10:10 PM
Hooked everything up per all the info I got and the horn continually sounds. Figured if was something in the steering column. Took it apart and stripped it. The horn still sounds! WTH?
