Topics128,026
Posts1,055,410
Members48,422
Most Online14,466Apr 26th, 2026
AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
over 30 years! and not clogged down with Ads! Again, thanks!
Going to install a horn relay in my 51. Its marked with the following numbers: 30, 85, 86, 87. Whats the proper makeup for this relay?
1951 Chevy 3100 5-window 261 cu in, 348 Head, Split Fenton Exhaust Offy with Dual Weber 2 Bbl Carbs
By the way, they are aftermarket modern horns.
What brand & model-number horn? What brand & model-number relay? And/or post/attach photos of both.
Both are Hella Products. The relay is model 960 388-46. 12v
Here is a typical installation absconded from the googler.
Another quality post.Real Trucks Rattle HELP! The Paranoids are after me!
Looks like what I need but....the relationship between the 85 terminal and the 30 terminal. Is it saying I need to jumper the two terminals?
Yes, although you could power each one separately from different circuits.
1951 Chevy 3100 work truck Follow this saga in Project Journal Photos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car)
The relay is a Bosch relay. The attached is similar to Rusty Rod's diagram, but shows the internals of the relay. don
Hooked everything up per all the info I got and the horn continually sounds. Figured if was something in the steering column. Took it apart and stripped it. The horn still sounds! WTH?
