2 members (2-Ton, Phak1), 116 guests, and 2 robots.
Topics128,115
Posts1,056,624
Members48,450
#1377 06/12/2004 11:23 AM
Junior Member
Junior Member
I just put a new crate engine in my 70 chevy truck. It's a Gm 350 HO with a Holley 770 carb. I'm getting gas in my oil. Both GM and Holley say the carb is not too big. So it isn't the carb pushing too much gas into the engine. The guy from Holley asked if I had a vented gas cap. I did put a new locking gas cap on and I'm pretty sure it's not vented. He said all 70's had vented gas caps to prevent too much pressure building up in the tank. he also said that the pressure builds up and when the engine is shut off it continues to push fuel into the engine which ends up bleeding over? the rings and into the oil. Does this make sense?
#1378 06/12/2004 1:47 PM
Scott: yes!! popcorn The Truth is Out There (770 Whoa!! oh I forgot I got a 750 sitting on mine)
#1379 06/12/2004 2:54 PM
I guess I am dumb but if the fuel pump removes fuel from the tank wouldn't that cause a vacuum situation and not a pressure situation? How could a vacuum push fuel into the engine? Enlighten me please.
I could see how expanding fuel on a hot day might push, but he mentions pressure building up with the engine running.
54 3100 with 235
62 flatbed dump C60 with 261
#1380 06/12/2004 3:27 PM
Time for a compression test! grin
#1381 06/12/2004 3:47 PM
I had a '75 Hornet which got gasoline into the oil through a bad fuel pump. I went to check the oil one day. It was a quart over full and really smelled of gasoline.
#1382 06/12/2004 4:57 PM
I once had a defective stock fuel pump. It was leaking gas directly into the bottom of the engine, where it sat at the side of the block.Do you have an electric pump or a stock one?
#1383 06/12/2004 8:15 PM
The non-vented caps are used with a charcoal vapor canister on the newer-model vehicles. The canister stores the vapors while the engine is stopped, then vents then through the intake system on startup. Older fuel systems either have a tank vent, or a vented cap, or both. I'd check for a leaky fuel pump, putting raw gas into the crankcase.
#1384 06/13/2004 3:33 AM
Junior Member
Junior Member
The consensus seems to be that the fuel pump is the problem, so I'm putting a new holley fuel pump on in the morning.
