6 members (Bill Hanlon, Gdads51, Otto Skorzeny, UtahYork, dt235sd, Ponchogl), 115 guests, and 5 robots.
Topics128,089
Posts1,056,130
Members48,435
#1379681 10/05/2020 11:00 PM
Would somebody have an original 1946 Chev or GMC pickup.I would need the distance between the Radiator Support and the Cab.Also if possible the height of the Radiator Support in relation to the Cab.I am trying to set up and fabricate my rad support and it's proving to be a challenge.This is for a project that I bought and the previous owner had already discarded the frame.Thanks.
1946 GMC Pickup,Small Block Chevy,Custom Frame
back yard wrench turner
this might help click
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
If that does not help, PM me and I will get you all the measurements you want. I will make you a drawing if necessary, I had to make one for one of my trucks and will have to make another. Dave
1941 Chevy
"First rebuild - complete!"
Follow the story in the DITY
1941 GMC resting peacefully
1946/1947 Chevy Street rod on s10 frame complete
1945 GMC panel truck in line for restoration
1941 Plymouth stock complete
1941 GMC COE in restoration process
Read his Project Journal
1941 Chevy Coe uncertain future resting now
Hi homer 52
I can’t PM because i am new here. I checked wayne67vert’s drawings but don’t have what I need. If you could get the distance from firewall to rad support and tell me were you mesured that would be great. Thanks.
I will get whatever you need, I just put my 41 away for the season and when I go to my shop I can get everything you need. I am going to try to send you a pm..
1941 Chevy
Holy, has enough posts now to be out of newbie moderation, so, if it’s enabled in his profile he can get PM’s.
By the way, I have an original 41 and a 46/7 on an s10 so I can get one the other or both.
1941 Chevy
The distance should be the same on either truck. I am using a 1981 z28 front clip and custom built frame for the rest going to the back with a 4 link rear with air bags.
If anyone else is reading this thread, the measurement we are talking about are very different between the GMC and Chevy. Hood divider is different and fender extensions are different and the radiator support also, they are not interchangeable.. Dave
1941 Chevy
I would like to give a big shout-out to dave (Homer52)for the mesures and the awesome pictures and for taking the time to figure it out. Thanks.
