2 members (Stovebolt48, 1 invisible),
131
Mod | | | Forums66 Topics128,211 Posts1,057,473 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2020 Posts: 4 Moderated | | Moderated Joined: Oct 2020 Posts: 4 | Why will my motor not turn fan when trying to start? Fan will spin every once in a while when trying to start. Have a 19/32” x 43” belt installed. Please help I have 4 young kiddos ready to take this bad boy for a ride. | | | | | Joined: Feb 2004 Posts: 29,889 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,889 | Have you tried to turn the fan with the belt removed? Chances are the water pump is locked up. I'm 40 miles north of you, and I've got several 216 pumps if you want to try another one before you buy a replacement. Jerry
| | | | | Joined: Oct 2020 Posts: 4 Moderated | | Moderated Joined: Oct 2020 Posts: 4 | Yes sir, I can turn fan without belt, It is tough but I can. Thank you so much for the offer on using a pump. | | | | | Joined: Feb 2004 Posts: 29,889 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,889 | The fan and pump should spin freely. You need to change the water pump. Make a couple more posts and you will be able to use the private message function of the site. Jerry
| | | | | Joined: Oct 2020 Posts: 4 Moderated | | Moderated Joined: Oct 2020 Posts: 4 | Awesome, I have one on the way. Thanks for your help Jerry. | | |
