6 members (2-Ton, DadsFirstPickup, Ponchogl, 32Fordpuchoptop, dt235sd, 1 invisible), 96 guests, and 1 robot.
Topics128,049
Posts1,055,674
#1379378 10/03/2020 2:57 PM
[img]http://20201002 16515[/img]
Just completed a 2 to 3 month project I started in Nov. 2019 . Repowered it and did a bit of body work and a quick paint job , some of which was scratched off reassembling it , Just in time to put it away for the winter but I hope to put a few hundred miles on it before then .
good planning is no substitute for dumb luck
panel fan #1379381 10/03/2020 3:01 PM
[img]https://www.stovebolt.com/ubbthread...umber/23093/filename/20201002_165155.jpg[/img]oops pictures didn't appear , I'll try again .
panel fan #1379382 10/03/2020 3:02 PM
Your image link does not work for me.
Look down on the lower-left of this page: "Image Posting Policy - Posting Images on the Stovebolt Forums".
This might be a little tricky (maybe impossible?) if you are using a tablet or phone?
panel fan #1379394 10/03/2020 4:57 PM
Hope that works , my son in law the computer geek happened to drop by and viola !!
panel fan #1379402 10/03/2020 6:09 PM
Looking good.🛠
panel fan #1379403 10/03/2020 6:21 PM
Wow
What truck-size frame is that?
panel fan #1379410 10/03/2020 7:39 PM
Wow again that thing looks long.... eeeek
panel fan #1379417 10/03/2020 8:33 PM
Factory one ton frame , I think a 133 wheel base , but the working floor is 10 1/2 long , truck over all is 20 ft. long
