4 members (dunfire, John Dlugos, Gdads51, Greg_H), 69 guests, and 8 robots.
Topics128,187
Posts1,057,211
Members48,465
Looking for these in 6bolt for a ‘60 k10–I remember these from the 80’s.
Let me know if you recognize. Also looking for some 3-clip steel wheels in 16”, and other 6bolt alum is wheel possibilities.
Post up what you run–much appreciated
Jw in MN
Be A Champion Every Day
As I recall GM has stayed with the 6 lug bolt pattern on all of their 1/2 ton 4x vehicles. You have to be careful when trying to upgrade wheels on 4x's and other HD pickups. GM is very particular with their wheel fitment. Original GM wheels fit the hub very closely, weight is spread out between the bolts and the hub. Most after-market wheels are 'one size fits all', there is a huge gap between the hub and the wheel, this gap put undo stress on the lug bolts, potential for failure. Wm.
1964 C10 with Railroad cab
60-66 Forum
1940 Chevy G506 4x4
Big Bolts
1937 GMC T14
Project Journal
From what I have researched, Chevy 6 bolt wheels are the same lug pattern. It's the center hole that is small on newer, late 80s and up, I tried to put my 65 wheels on my 85 hubs, rear is fine, front no good, hit the brake caliber. I was told you can use a dermal tool to enlarge the center hole on newer wheels. Waiting for a decent set of 17 inch to show up on cl, then I will try it.
1965 c-10 4 wheel drive conversion
Pix in the Gallery Forum
I run American Racing Eagle alloy 589s. My original set was 6 lug, 15" wheels with 285/70. Sure did fill up the space in the front fenders.
