1 members (klhansen), 70 guests, and 3 robots.
Topics128,094
Posts1,056,064
Members48,433
#1378672 09/27/2020 3:35 PM
1 Offline
Hello,
Can anyone tell me what what the holes labeled 1, 2, and 3 in the attached image are for. I cant seem to find a good reference picture and the engine was torn down when I received it. Holes 1 and 2 appears to go into the engine. Hole #3 appears to be a blind hole.
It is a 1954 235. The image is of the intake/exhaust side of the engine.
https://app.photobucket.com/u/1866y...e/p/26920686-6910-465f-a0a3-c6109faa1313
Thanks for the help.
1 may be for oil line for filter not sure will check on mine and let you know ,2 dont know 3,throttle linkage
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
Does 2 go into the water jacket?
Mike
Hole #1 is a return line port back to the crankcase for a bypass-type oil filter. Holes 2 and 3 are attachment points for different types of throttle linkage bell cranks.
Just confirming 1 is from oil filter and 3 is were my throttle linkage is hooked up
"The Journey"
Follow in the DITY
Either 2 or 3 will be for the throttle linkage, depending on the year of the vehicle, and possibly the vehicle the engine is installed into. Yes, the hole near the oil pan rail is for the return line from the bottom fitting of the oil filter.
1 Offline
Thanks everyone for the help. I appreciate it.
