2 members (tclederman, Phak1),
37
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,090 Posts1,056,031 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2012 Posts: 131 'Bolter | | 'Bolter Joined: Aug 2012 Posts: 131 | Hello, Can anyone tell me what what the holes labeled 1, 2, and 3 in the attached image are for. I cant seem to find a good reference picture and the engine was torn down when I received it. Holes 1 and 2 appears to go into the engine. Hole #3 appears to be a blind hole. It is a 1954 235. The image is of the intake/exhaust side of the engine. https://app.photobucket.com/u/1866y...e/p/26920686-6910-465f-a0a3-c6109faa1313Thanks for the help.
| | | | | Joined: Sep 2010 Posts: 2,307 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,307 | 1 may be for oil line for filter not sure will check on mine and let you know ,2 dont know 3,throttle linkage | | | | | Joined: Dec 2017 Posts: 1,652 'Bolter | | 'Bolter Joined: Dec 2017 Posts: 1,652 | Does 2 go into the water jacket?
Mike
| | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | Hole #1 is a return line port back to the crankcase for a bypass-type oil filter. Holes 2 and 3 are attachment points for different types of throttle linkage bell cranks. Jerry
| | | | | Joined: Sep 2010 Posts: 2,307 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,307 | Just confirming 1 is from oil filter and 3 is were my throttle linkage is hooked up | | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | Either 2 or 3 will be for the throttle linkage, depending on the year of the vehicle, and possibly the vehicle the engine is installed into. Yes, the hole near the oil pan rail is for the return line from the bottom fitting of the oil filter. Jerry
| | | | | Joined: Aug 2012 Posts: 131 'Bolter | | 'Bolter Joined: Aug 2012 Posts: 131 | Thanks everyone for the help. I appreciate it. | | |
