11 members (Jay R, wilbur53, Gdads51, TUTS 59, DaveV, RLB, WICruiser, Phak1, Otto Skorzeny, 55shaker, 1 invisible), 109 guests, and 4 robots.
Topics128,056
Posts1,055,789
#137844 04/17/2007 8:45 PM
What spindles do I need to convert my drum brakes to disc on the front? I need to stick to 6 lugs so my rally wheels will work. What truck spindles can I ask for at the local parts house and get the ones needed for this application?
#137845 04/17/2007 9:49 PM
Spindles from 71-87 work well, used is fine. The rotors are aftermarket only, CPP & ECE both carry them separately CPP page
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#137846 04/18/2007 2:16 PM
Brian, did you use truck or car spindles?
Why not take the calipers and rotors at the same time if they are usable?
#137847 04/18/2007 6:05 PM
I used 71 C10 spindles, sorry I just always think "truck". The 6 lug rotors are only available aftermarket(GM went to 5 lug w/the discs), use the calipers for cores or rebuild them. Brian
