| | | Forums66 Topics128,060 Posts1,055,839 Members48,427 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2004 Posts: 54 'Bolter | | 'Bolter Joined: Aug 2004 Posts: 54 | What spindles do I need to convert my drum brakes to disc on the front? I need to stick to 6 lugs so my rally wheels will work. What truck spindles can I ask for at the local parts house and get the ones needed for this application? | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Spindles from 71-87 work well, used is fine. The rotors are aftermarket only, CPP & ECE both carry them separately CPP page | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Brian, did you use truck or car spindles? Why not take the calipers and rotors at the same time if they are usable? | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I used 71 C10 spindles, sorry I just always think "truck". The 6 lug rotors are only available aftermarket(GM went to 5 lug w/the discs), use the calipers for cores or rebuild them. Brian | | |
