0 members (),
66
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | There is a good tech-tip about doing this. I tried to find the author in the member list without luck My questions were can I use the spacing block for the backing plate from the Huck system. Secondly do you have to do anything to the master cylinder. Any answers will be appreciated. Bill | | | | | Joined: May 2015 Posts: 10,997 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 10,997 | The tech tip says he used the Bendix spacer, but if the Huck spacers are the same thickness, you could drill out the mounting holes and use them. Not ever seeing Huck brakes, I'm guessing here. Master cylinder should work as-is, assuming it's the same piston diameter.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | I think he had a full axle to pull parts from. All I have are the backing plates. | | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | The problem with the swap is the difference in size of the holes in the steering arms. They are smaller on trucks with Huck brakes. The Bendix use larger diameter steering arm bolts, so there is a problem with the backing plates having holes which are too big for the Huck bolts. This leaves you with two choices. Drill the holes larger in the Huck steering arms, or welding the holes in the Bendix backing plate to a small diameter. I wasn't comfortable with drilling the Huck steering arms, so I welded plate steel to the backing plates on the wheel side and drilled the holes to fit the Huck steering arm bolts. Hope this helps. You kind of have to "be there" to visualize it clearly.
| | | | | Joined: May 2015 Posts: 10,997 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 10,997 | I would think it would be easier to enlarge holes (a larger drill will self center in the existing holes) than to weld and drill smaller holes (getting them centered where they need to be), but either way would work. Spacer blocks were mentioned, but I haven't dug into my brakes yet to see where they are.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | It's only 1/16" bigger, I just drilled the holes , been near 20yrs now , daily use . | | | | | Joined: Jan 2001 Posts: 1,421 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,421 | Did the same as Dusty, easy conversion, used the same Huck single MC.
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
| | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Sounds very doable. It is only a 1/16" difference in the steering arm holes. And I am happy to learn the original MC is good to use. Thanks all. | | |
