5 members (Steelonsteel, mason86, 55shaker, Hotrod Lincoln, Otto Skorzeny), 93 guests, and 1 robot.
Topics128,050
Posts1,055,684
#1378409 09/25/2020 5:09 AM
My butterfly hood on my 46 half ton is tweaked. the nose on the drivers side simply won’t sit down right. Thinking of making the good one solid piece. I’ve seen some that open from the back (nose dips down). Also ones that open from side (coffin style). Any good aftermarket kits or brackets? suggestions how to do this? Thanks 🙏
You have posted this in two Forums - that becomes awkward for members to follow the replies in the two threads.
Duplicate thread has been deleted from Paint and Body.
We have used the side lift kit from Hagan on several "Butterfly" hoods. I like the one with a independent prop rod over the one the rod slides into position as the hood is raised.
[img]https://i.postimg.cc/K1TLgxq0/Stude-Justin-s-40-Cougar-Cat-004.jpg[/img]
Evan
Crusing in the Passing Lane
Evan,
Do both sides open like that?
Ed
Ok. Sorry about that.
Thanks!
