2 members (2-Ton, 1 invisible),
108
Mod | | | Forums66 Topics128,034 Posts1,055,546 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2020 Posts: 22 'Bolter | | 'Bolter Joined: Aug 2020 Posts: 22 | Any one know what rim off set will work with a 16x7 rim on a 1950 3600 front axle? I’ve tried a couple and have trouble hitting the tie rod end. Thanks | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy NorAlta, welcome, I'm not sure what the actual offset dimension is, but years ago when building a 1952 one ton 1430 series we found that wheels from a F@#d van fit and did clear the tie rods. Hope that helps. | | | | | Joined: Aug 2020 Posts: 22 'Bolter | | 'Bolter Joined: Aug 2020 Posts: 22 | | | | | | Joined: Jan 2016 Posts: 631 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 631 | Etrailer ....... Taskmaster Steel Modular Trailer Wheel - 16" x 6" Rim - 8 on 6-1/2 - Black. new $95 https://www.etrailer.com/Trailer-Tires-and-Wheels/Taskmaster/T166BM8.htmlZero offset pretty much solves the tie rod issue. Other sizes and colors available......
