6 members (sron48, 55shaker, Bill Hanlon, Lightholder's Dad, JW51, Forty9), 196 guests, and 7 robots.
Topics128,080
Posts1,055,956
Members48,430
#1378005 09/22/2020 2:23 AM
Any one know how to fix a park brake so it will lock when pushed down? '50 GMC 150. Thx.
Joe
1947 Second Series GMC 1-Ton Longbed
More pix in the Bolt Bucket
I would guess that the lock has been worn. It needs a fairly sharp edge where the pedal shaft goes thru it to grab the shaft. Could also be that the spring is weak as well. You might be able to remove the locking bar and use a file to "sharpen" the hole. Otherwise, you probably need to replace the locking bar.
Make sure your lock bar is paint/rust free. I had to sand mine to insure it held--Good Luck--Bill
I had the same problem on my '41. Removed the ratchet and sharpened it with a file. It's very hard, wore out a 3 corner file sharpening the teeth but it works now.
Harold Wilson
41 Chevy 3/4 Ton
Y
Y Offline
What has worked for me, was putting more "bend" in the for lack of better name the arm that the shaft goes through.
