3 members (klhansen, 3800GUY, 1 invisible),
63
Mod | | | Forums66 Topics128,153 Posts1,056,847 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2017 Posts: 230 'Bolter | | 'Bolter Joined: Apr 2017 Posts: 230 | I’m getting ready to choose the paint color for the interior of my truck.
The outside is some shade of Brewster Green
Is the entire cab painted the same color... inside and out? The outside color is used for the jams, floor, seat pan, inside firewall etc... underneath the trim panels?
Are the inside trim pieces, door panels, back wall panels, dashboard all painted the same color? What is the most common color?
How about the headboard? Was that painted the interior color? What would the color be? If not painted, what does it look like?
The instrument gauges are painted a tan color (or decal color). What color is the surrounding plate?
Should that be the same as the other painted trim panels and dashboard?
Mike
1940 Chevy 1/2 Ton presently... Almost done 1940 Chevy Business Coupe... In pieces
| | | | | Joined: May 2015 Posts: 11,134 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,134 | Here's' some info on interior color. 1940 1/2 ton paint schemeEverything inside would be painted the same color. On AD (47-54) trucks the demarcation between interior and exterior would be at the door weatherstripping. I'm assuming it would be the same for the earlier trucks. As a point of interest, I was just looking at my original gas tank, and apparently it was installed prior to interior paint because it was painted interior color.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Another way to state where the paint-color "demarcation point" is on a truck/cab that has no weather seal/stripping installed:
The outer color ends where the outer skin (sheet metal) ends (over the inner sheet metal). | | |
