1 members (Cosmo),
84
Mod | | | Forums66 Topics128,054 Posts1,055,779 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2019 Posts: 83 'Bolter | | 'Bolter Joined: Jul 2019 Posts: 83 | I have a '41, AK with a 228 and a 4 speed. Just replaced clutch and throwout bearing and there is a ratcheting sound from transmission area when I slow down. I can only hear it at low speeds i.e...rolling to stop sign. Doesn't matter if clutch in in or not. I have heard a lot of different driveline noises but not this one. Any ideas? | | | | | Joined: Mar 2010 Posts: 10,274 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,274 | A loose or worn U-joints will make that sound.
| | | | | Joined: Mar 2019 Posts: 1,003 'Bolter | | 'Bolter Joined: Mar 2019 Posts: 1,003 | Was the noise there b4 you serviced the clutch? If not, you did it. Look at what you may of changed. If there is a carrier bearing? Make sure you didnt install the retainer backwards. It really looks like it wouldnt matter, but it does. Trust me, i learned the long way.. | | | | | Joined: Jul 2019 Posts: 83 'Bolter | | 'Bolter Joined: Jul 2019 Posts: 83 | After clutch, TO bearing , u joints all replaced. | | | | | Joined: Mar 2019 Posts: 1,003 'Bolter | | 'Bolter Joined: Mar 2019 Posts: 1,003 | Id get it on jackstands and try to duplicate the noise. | | | | | Joined: Mar 2019 Posts: 1,003 'Bolter | | 'Bolter Joined: Mar 2019 Posts: 1,003 | Another thing. Look at stupid crap. Like speedo cable routing, etc. Make sure nuttin is near the driveshaft. Loose ubolts on ujoints will make all kind of racket also. Keep us posted. U got me curious 🤔 | | |
