7 members (Goach2, Donf, Rusted Nut, Bill Hanlon, JW51, BC59, 1 invisible), 61 guests, and 3 robots.
Topics128,176
Posts1,057,122
Members48,463
I am getting less than a thimble of antifreeze dripping on the floor under my 1959 Chevy PU. I have almost traced the leak to the source but... It comes down from the back of the head and above the bell housing. It runs down the right side of the bell housing and into the lip of the flywheel inspection cover and out the little hole. Initially I thought it was a freeze plug but they are lower than the leak. All I can identify above the bell housing is the head, which could have a crack. Any ideas from the group? I will say I flushed the block and replaced the radiator and had MUCH rust. I then used a rust melter in the block for 3 days and now no rust. Maybe I loosened up an old leak.
1959 Chevy Apache Stepside Truck
Try re-torqueing the head. It can't hurt, and it just might help. Loosen the bolts about 1/2 turn one at a time, following the factory torque sequence, and retighten them. You're probably headed for a head gasket change, but it never hurts to make one last stab at a quick fix.
Riding in the Passing Lane
There are some core plugs (freeze plugs) behind the manifolds that can leak sometimes & run down the back of the engine. A pressure test may help locate it.
George
1972 Chevy c10 Cheyenne Super
Curmudgeon
Curmudgeon
If it's not leaking at the head and/or head gasket, it could be the rear freeze plug.
It's covered by the bell housing.
Picture borrowed from Deve's website.
2 Offline
Also something to consider
I have a small coolant leak in one of my 235s that’s right in the middle of a flat spot on the side of the block, not even at a seam or ridge in the casting
So a defective block is possible too
Just like 59rebuild my leak was only noticeable after I cleaned the rust out the block, before that it was dry (oily and dirty tho).
-s
I sealed a small crack/leak with epoxy cement/glue in the same location on my Suburban’s 1960 261 block over 15 years ago (based a recommendation/suggestion posted here).
It has not leaked since then.
What is the condition of this engine in terms of how long before it may need an overhaul?
If its high miles (over 60-70k miles for these engines most of the time), add some stop leak in it to buy you some time until a rebuild is in order. I did that on well worn, but great running 216 which had a 5 inch crack in the water jacket by the petcock drain. It still had a bit of a weep, but did not leave a puddle. I drove it for 20,000 miles after that with no issues.
I really do not know though it runs very well, no strange noises, good power. I bought it and restored with partial cab/engine on frame. The only thing I notice is moisture out the exhaust when it first starts up which I figured was due to being cold and moisture had settled in the ehaust.
My leak is above the bell housing and dripping down the side, into the flywheel inspection cover.
I will give that a twist, no pun intended.
George
I'll check the pressure. These plugs are different than those behind the bell housing, correct?
