| | | Forums66 Topics128,119 Posts1,056,313 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2020 Posts: 4 Moderated | | Moderated Joined: Sep 2020 Posts: 4 | Hi folks. I'm the New Kid ðŸ˜. I'm resurrecting a '48 Chevy. Chevyofthe40s says it has an Ammeter NOT a voltmeter. And I therefore won't need a dropping resistor to use a 12V system. I want to use all original gauges. So QUESTION: Which post on the Ammeter gets 12V Positive and which do I ground? There are no marks to indicate it and I am the 4th owner in trying to bring it to life. So I didn't take it apart. (I have a '49 Studebaker pickup, so I'm not all bad). Thanks in advance.
Kenneth R Brown
| | | | | Joined: Dec 2002 Posts: 3,441 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,441 | Hello Kenny, please do NOT wire your ammeter to ground. I just saw a post that shows how they are to be wired, but surely someone else will chime in soon. Also, please drop into the welcome forum and introduce yourself to the TRUCK FORUM, where car questions are usually sent to the greasy spoon to be resolved. here is the link that will give you an idea of how things are normally wired! https://www.vintageautogarage.com/v/vspfiles/files/alt-wire-diagram-10.14.pdf
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Might be a good idea to learn about simple electricity someplace to learn how it works, pretty simple, just a few basics would help.
Ammeters do not care about voltage, just flow, so, if one turns on the headlights or some other load with the engine off, the ammeter should indicate negative, if reads positive, just change the leads. The whole electrical load less the starter, should feed through the ammeter, lead goes from the starter large starter terminal directly to the ammeter to feed the whole rest of the truck, which gets fed from the other ammeter terminal.
Ed
| | | | | Joined: Oct 2020 Posts: 3 Moderated | | Moderated Joined: Oct 2020 Posts: 3 | I just rewired my '49 Chevy 3/4 ton Step Van. The way I did it is I ran a 10 gauge wire from battery terminal on Solenoid to the D (Discharge) side of ammeter and a 10 gauge wire from D to St on ignition switch. Then with the same gauge wire I ran from bat. (battery) on ignition switch to C (Charge) side of ammeter. My ignition switch has 4 terminals (Bat., Acc., St., & Ing.) St. is in center with the others in a triangle shape. This worked for me. | | | | | Joined: Nov 2002 Posts: 394 'Bolter | | 'Bolter Joined: Nov 2002 Posts: 394 | I am seriously thinking about changing from my gen./reg. to a alternator. I keep hearing about a one wire alternator set up, meaning going from the alternator Bat. terminal straight to the battery. One would think there has to be more to it than isn't there? | | | | | Joined: Feb 2019 Posts: 4,482 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,482 | I have a one wire alternator and it is that easy, but there are drawbacks. Here’s an article by Rod Authority that points out the differences. One Wire vs. Three Wire Alternators
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | |
