Replaced my whole floor pan/toe board in my '50 3100 and the old one is now MIA. I need the pockets that go around the pedals to hold the weather seals and brackets for the gas pedal. Any help is greatly appreciated! [img]https://photos.app.goo.gl/7aLRKRKMfytxjiuP7[/img]
Jason
Working on my first restomod on a 1950 3100 Shortbed (235 engine, 3 on the tree, disc brakes, etc.)
If you can't find them, it wouldn't be that hard to fab up replacements. I sent dimensions to a member a while back for the accelerator pedal pivot bracket. That one would be easy, as well as the accelerator pedal stop. The pockets for the other pedals would be a little more difficult, but not impossible.
Kevin 1951 Chevy 3100 work truck Follow this saga in Project Journal Photos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together.
For the shape you're showing for those recesses, a simple punch made out of square tubing and a larger piece of square tubing to act as the female die... Then an H press or big hammer..
Here's a punch and die we used for a bolt clearance void, similar setup could be used for those shapes you show..
As Bolters, aren’t we obligated to never throw out anything? Ever?
Ugh, back to tripping over stuff I’ll never use in the parts shed.
Because, as we all know, the second it’s gone we need it.
1970 Chevrolet C10 Grandpa's -- My first truck -- In progress to shiny Follow the build in the Project Journal 1950 Chevrolet 1-Ton Dually "Ole Red Girl" In the Stovebolt Gallery More pictures here 1951 GMC 9430 1 ton dually--Shiny! | 1972 Chevrolet C20- Rusty- the puzzle box lid for the C10 | 1962 AMC Rambler American- my wife's Parts trucks- 1951 GMC 9300 | 1951-GMC 9430 | 1951- Chevrolet 1300
I still have one of the accel pivot brackets I fabbed up and the clutch & brake brackets for the pedals (from a 1951). But do not have the accel seal bracket. Pm me if you are interested!
1951 Chevy 3100 "Project for my Wife" - Jigsaw Puzzle 1969 Camaro SS350 convertible 1969 Camaro 327 convertible
Thanks everyone a fellow bolter just sent me some. So I got what I need. For anyone else that may run across this in the future apparently the new floor plans from classic industries now include these if you buy theirs, which I did not!
Jason
