2 members (Samantha, klhansen),
308
7
Mod | | | Forums66 Topics128,162 Posts1,057,042 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2020 Posts: 93 Shop Shark | | Shop Shark Joined: Apr 2020 Posts: 93 | I need to primer some small pieces of the front suspension. The primer suggests using a 1.3 to 1.7 nozzle. My detail gun has a 1.0 for the larger nozzle. Do I need to thin the primer or??? Will it even work? I want to use the small gun so I do not waste a lot of paint by shooting a wide pattern out of my paint gun for a 1 inch wide part. | | | | | Joined: Oct 2017 Posts: 54 'Bolter | | 'Bolter Joined: Oct 2017 Posts: 54 | It should work fine on short run of small parts. Try it, on scrap, not much risk. What kind of detail gun.
1959 Apache 31
| | | | | Joined: May 2015 Posts: 11,152 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,152 | Isn't the pattern width on your gun adjustable? I can set mine for a round pattern or a wider one. You just need to fiddle with the material and width knobs. But a detail gun should work fine. You may need to thin a bit more than for one with a larger nozzle.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Apr 2017 Posts: 230 'Bolter | | 'Bolter Joined: Apr 2017 Posts: 230 | The small opening of 1.0 of your gun will lay down small paint droplets. You need to have larger droplets for primer. Primer is thicker so you need a larger opening. Prob 1.4-1.6. Your Paint data sheet should say what you need. You can but a $15 purple gun at harbor freight which comes with a 1.4 mm tip and drill it out to 1.6 if you need to ... it would take about a 1/16 inch Drill bit. Works great.... do it all the time. The needle is tapered so it will fit.
The last time I bought a HF gun, I had to go through about 15 to find one where the needle wasn’t rusted.
Mike
1940 Chevy 1/2 Ton presently... Almost done 1940 Chevy Business Coupe... In pieces
| | | | | Joined: Apr 2020 Posts: 93 Shop Shark | | Shop Shark Joined: Apr 2020 Posts: 93 | I have an Eastwood set of Contours guns. The large gun works great but... even when I dial the pattern width down I waste a lot of paint. Most of the paint misses parts that are long and thin in the steering assy, torsion bars and also parts with many nooks and cranny's like the A-Arms. Maybe that is just part of painting and I have to live with it. I am just trying to find a good way to save paint and still get a quality finish. I will post some pictures in a week or so after I finish painting the front steering and suspension parts. I am quite pleased with the Eastwood Guns. For a rookie who has only used guns to paint house siding I really like the finish I am getting. Good coverage and only runs if you really overspray. Nooks and cranny's are still tough as the large gun is hard to maneuver. | | | | | Joined: Oct 2005 Posts: 4,260 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,260 | Sometimes, that's just part of painting!! | | | | | Joined: Sep 2010 Posts: 1,717 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,717 | I have found an airbrush works good for small parts and tight spaces. Wayne1938 1-Ton Farm TruckStovebolt Gallery Forums1989 Silverado 1996 Mustang GT convertible When I die, I hope she doesn't sell everything for what I told her I paid for it! | | |
