1 members (Hotrod Lincoln),
130
Mod | | | Forums66 Topics128,143 Posts1,056,494 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2020 Posts: 21 'Bolter | | 'Bolter Joined: May 2020 Posts: 21 | Would anyone have any photos of the1959 3100 rear brakes and possibly some installation advise/how to/tips? | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Do you have a shop manual? Have you searched You Tube? Both of those will more than likely have the info you need. It's pretty straight forward...as you take it apart take pictures so you can put it back the same way. Is your truck US or Canadian? Mike B  | | | | | Joined: May 2020 Posts: 21 'Bolter | | 'Bolter Joined: May 2020 Posts: 21 | Hello. It’s a US truck. I do have the manual and have checked youtube. There wasn’t anything specific to a 59 on YouTube but I am assuming that years close shouldn’t be too far off. | | | | | Joined: Apr 2005 Posts: 2,098 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,098 | Chevy used the same Bendix brakes on cars and trucks from 51 through about 63. Later vehicles used the same brakes but the hardware was different because of self adjusters. Fred
