3 members (2-Ton, Leo, stlcardinalsguy), 125 guests, and 1 robot.
Topics128,136
Posts1,056,426
Members48,441
#1376737 09/11/2020 6:38 PM
Looking at 1958 235 out of Delray. Considering putting it into my 1959 3100 Napco. The current engine in my Napco is a 1960 235 out of a car and I wanted to get an engine that was closer to original dates. From what I understand it was not unheard of to have a 58 stamped engine in a 59 truck? On my 1960 235 the carb linkage needed altered. My question is, are there similar differences between a 1958 235 out of car versus out of truck?
Not sure it's worth all the trouble.
Thanks again for your advice/help.
BrianM
1960 was the first year to drop the front throttle pivot option, resulting in the need to do throttle linkage work.
Here is a link to my blog post that addresses that.
Blog post
My Blog
BrianM #1376745 09/11/2020 10:02 PM
Curmudgeon
Curmudgeon
The obvious things:
Cars have an electrical solenoid starter and trucks a mechanical activated starter (except truck Hydramatic transmission).
Cars have an automatic choke. Trucks manual.
Cars with automatic transmission had engines with hydraulic lifters. All trucks solid lifters.
On-and-on.....other stuff....but nothing that can't be swapped out.
The same 1958 car casting number for head and block could be used by GM in the following year 1959 truck.
I'm guessing, but the stamped engine serial number is usually correct for the year the engine was fully assembled.
On the other hand, I've personally seen a 1953 truck that was titled by GM as a 1954.
1959-62 engines had a change in the rocker arm oiling system.
You would not want to install the 1958 head and rocker arm assembly on the 1959 or later block. Some homework required.
I only mention this in case you want to mix and parts in the future.
BrianM #1376751 09/11/2020 10:28 PM
"Cars have an automatic choke. Trucks manual."
(except truck with Hydra-Matic transmission - they had automatic chokes)
BrianM #1376755 09/12/2020 12:06 AM
Other things to consider. In 59, Chevrolet made the last of the upgrades to the 235, Including improved oiling to the rockers. So your 60 has all,of the last upgrades GM mad to that platform.
Mike
GM never created a "title" for any of their vehicles, that was and still is done by the State the vehicle was first sold in. Many States back in the day titled vehicles by the year in which they were sold, not by the model year.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
You guys are a wealth of knowledge, ALWAYS learning something new, and thanks buoymaker. Ed
Thank you. It is always amazing to find out how much I don't know. I think I may stick with the good running 60 engine until a good 59, from a truck comes around.
I'm probably over thinking the whole matching numbers thing and should just enjoy my truck. I'll let my daughter worry about resale value!
Once again, thanks for your help.
Brian M
