1 members (porsche),
111
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,051 Posts1,055,767 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2020 Posts: 1 Moderated | | Moderated Joined: Aug 2020 Posts: 1 | I have a 1959 Chevy Apache. I need to replace the gaskets on both the front and back sides of the rear. I also need to replace some of the nuts/bolts/washers as some are missing, and the drain/fill plug. Problem is, I do not know what type of rear I have to be able to order exactly what I need. The numbers on the rear are:
3707340 D1
And
AF1125
Using these numbers, is anyone able to tell me what I have and also able to suggest where I could obtain the needed parts?
Pat Greene
| | | | | Joined: Dec 2011 Posts: 112 'Bolter | | 'Bolter Joined: Dec 2011 Posts: 112 | Apatrick A picture would be worth a 1000 words! delky dave in wyo
1957, 3100, v8 2016 gmc 4wd
| | | | | Joined: Jan 2013 Posts: 2,232 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,232 | Apatrick,
I am moving this to the driveline forum so you will get the info you need.
Chris | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | You have a Regular Production Chevrolet 1/2 ton 3.90:1 rear per your stamped number AF1125. AF = 31 & 32 Series 11 = month (November) 25 = Day Mike B  | | |
