6 members (sron48, Charles in CA, Gray_Ghost, 66flea, Wally / Montana, dt235sd), 72 guests, and 1 robot.
Topics128,050
Posts1,055,757
#1376486 09/09/2020 1:49 PM
Moderated
Moderated
I have a 1959 Chevy Apache. I need to replace the gaskets on both the front and back sides of the rear. I also need to replace some of the nuts/bolts/washers as some are missing, and the drain/fill plug. Problem is, I do not know what type of rear I have to be able to order exactly what I need. The numbers on the rear are:
3707340
D1
And
AF1125
Using these numbers, is anyone able to tell me what I have and also able to suggest where I could obtain the needed parts?
Pat Greene
Apatrick #1376585 09/10/2020 2:30 AM
Apatrick
A picture would be worth a 1000 words!
delky dave in wyo
1957, 3100, v8
2016 gmc 4wd
Apatrick #1376840 09/12/2020 9:56 PM
Apatrick,
I am moving this to the driveline forum so you will get the info you need.
Chris
Apatrick #1376851 09/12/2020 11:14 PM
You have a Regular Production Chevrolet 1/2 ton 3.90:1 rear per your stamped number AF1125.
AF = 31 & 32 Series
11 = month (November)
25 = Day
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
