| | | Forums66 Topics128,030 Posts1,055,423 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2020 Posts: 620 'Bolter | | 'Bolter Joined: Jan 2020 Posts: 620 | Is the GM Delco Rochester part number 7029751 the correct # for a 235 application? If so I'm going to buy three NOS still in the box. Doc.
| | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | | | | | | Joined: Jul 2000 Posts: 2,188 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,188 | Rochester model B manual choke for Chevy/GMC truck 235 6. Part number for throttle body assembly for 1959 to 1962 is 7013899. For 1953 to 1058 is 7005643.
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Aug 2018 Posts: 351 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 351 | Doc,
Nope, not a number that corresponds to the carbs for the 235s. That number is for the throttle body listed for 230s, as Panic said. Might it work? Yes, but it's hard to say how close the calibration may be.
Doug | | | | | Joined: Jan 2020 Posts: 620 'Bolter | | 'Bolter Joined: Jan 2020 Posts: 620 | Thanks guys, you saved me from spending the money on Ebay. 12bolt_tom has quite a few parts which he bought from a Studebaker warehouse. He is good to work with. Doc.
