3 members (papas52, BobbyV, Gib70), 111 guests, and 1 robot.
Topics128,113
Posts1,056,613
Members48,450
Hello,
which torgue do you fix the screws that fix the plate of the differential housing?
I mean this:
https://www.kripahle-online.de/unterricht/wp-content/uploads/2020/08/IMG_3740-scaled.jpg
Wolfgang
I'm working on a Chevy Pickup 3600, build 1953 with an 235 cui engine.
Here you can watch my truck: https://www.kripahle-online.de/unterricht/?page_id=2532
H Online: Content
Torque isn't terribly important on bolts like those, but here's a simple procedure. Tighten the bolt until all the looseness is taken up (no gap visible between the bolt and the cover) then turn the bolt head 1/6 to 1/4 turn tighter to compress the gasket slightly and prevent the bolt from loosening. Overtightening a bolt on a sheet metal cover can distort the cover and/or damage the gasket. You could also use a drop of a thread locker such as Loctite (blue color, not red) on the threads.
Ok, thank you for your answer.
When I tighten this type of bolt I never use two hands on a ratchet wrench. I grip the ratchet mechanism in my palm with the ratchet head under my thumb and forefinger, that way the only leverage is the length of my palm from the forefinger to the little finger. I find it easier to limit the amount of torque this way.
Harold Wilson
41 Chevy 3/4 Ton
I agree that you can easily over-torque a joint like this. The techniques described to achieve proper bolt tension are good practices.
The other practice I follow is to tighten bolts evenly in a crisscross or "X" pattern for a cover like this.
Rusty
What?? You don't torque them till they break and then back off a half turn? eeeek
And another question,
which torgue do you fix the screws rings? Look here: https://www.kripahle-online.de/unterricht/wp-content/uploads/2020/08/IMG_3741-scaled.jpg
The rings which fix the wheel bearings.
Wolfgang
If you're talking about the wheel bearing adjusting nut, there's no torque spec for that. What you do is tighten it (the service manual just says "tight") while turning the wheel hub, then back it off by 45 degrees. Be sure the wheel hub turns freely by hand. Then install the lock nut and secure it by bending a tang.
Thanks for your answer.
Wolfgang
