8 members (Oldcaliforniakid, Otto Skorzeny, jmoore, frogfarmer, Hotrod Lincoln, 49nut, Stovebolt48, mason86), 114 guests, and 0 robots.
Topics128,050
Posts1,055,671
#1376144 09/06/2020 4:23 PM
(you guys say no thing as stupid question)
As I'm about to mount the 235 on engine stand,
I 'sized' the obvious bolt holes I'll be using -
3/8-16 goes part way in. I got out little thread
gauge - unless it's wrong, these are 14 tpi.
Is this right ? Do I need to find 3/8-14 bolts ?
1960 C20 Platform
dbwr #1376151 09/06/2020 5:34 PM
Mine are 7/16 - 14.
51 GMC 100 with 59 chevy 261 under the hood.
3 on the floor with 3.42 gear.
dbwr #1376154 09/06/2020 6:07 PM
Moderator
Moderator
2 Offline
I don't think there is a 3/8- 14 tread on any Stovebolts. Or that size was ever produced for anything.
It is probably a 1/2-13 thread.
When I mounted a 235 on the engine stand, I used 1/2-13 bolts.
In fact, that is the only size bolt I have used, be it GM, Ford, or Chrysler.
No DB, there are no stupid questions on this site.
If it saves someone some hurt or money, we are here to help!
Don
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
dbwr #1376195 09/06/2020 11:48 PM
The only bolt size with 14 pitch threads would be 7/16 inch. But those are fairly uncommon. It's unlikely you'd find that size at your local hardware store.
I'll find out tomorrow, when I crawl under
and pull an existing bolt. Don't really see
a ½" fitting in there. It was 100º and I'm
too old to crawl around in the heat.
1960 C20 Platform
dbwr #1376218 09/07/2020 2:25 AM
H Online: Content
The stovebolt bellhousing is attached to the block with 7/16-14 thread bolts. There's no way to get a 1/2" bolt to fit unless you drill and tap the block for bigger bolts. I just finished bolting the adapter for an engine stand to a 216 block, and 235's and 261's use the same bellhousing bolts as a 216.
Truck transmissions (SM-318 and SM-420) are bolted to the bell housing with 1/2-13 bolts.
Standard thread bolts (UNC) are as follows:
3/8-16
7/16-14
1/2-13
Fine thread bolts (UNF or SAE):
3/8-24
7/16-20
1/2-20
dbwr #1376219 09/07/2020 2:39 AM
Moderator
Moderator
2 Offline
Darn, I forgot about the 7/16-14 threads.
Thanks for the reminder!
Don
"The Flag Pole"
1953 1-ton pickup
dbwr #1376226 09/07/2020 3:04 AM
dbwr,
It was hot here today in Fort Collins. 100 yesterday, 99 today. Tuesday it's supposed to be a high of 34 and 4 inches of snow... Gotta love Colorado!
-David
1953 2-Ton GMC
dbwr #1378280 09/24/2020 1:57 AM
Turns out they are indeed 7/16 x 14 tpi.
Now just need a bit more time to get to work on it.
1960 C20 Platform
dbwr #1378285 09/24/2020 2:12 AM
Crusing in the Passing Lane
Just as a general guide, NC bolts are usually used in cast iron and aluminum(Al).
NF bolts are usually used in steel.
Ed
