9 members (artinva, Peggy M, VicZ, Ridgeback, RAC1812, Shaffer's1950, Gdads51, klhansen, 1 invisible), 121 guests, and 0 robots.
Topics128,077
Posts1,055,928
Members48,430
Working on a 58 GMC 1 ton Napco and installed a new turn signal switch. All lights working correctly but in the rear brake lights are activated by turn signal switch and not the brake pedal(new switch installed 2018). When I unplug the white wire out of the switch the brake lights do not come on with the switch or the pedal and the turn signal lights work fine. Any ideas? Thanks Pat
58 1 ton Napco
59 1/2 ton Napco
58 1/2 ton Napco
55 1 ton 9’ bed
58 3/4 ton stepside
55 LCF boom truck
(3) 57 2 tons
Riding in the Passing Lane
Test for power at the white wire when you press the brake pedal. If it is not hot you have a bad stop light switch or blown fuse.
George
1972 Chevy c10 Cheyenne Super
