0 members (),
118
Mod | | | Forums66 Topics128,196 Posts1,057,393 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 70 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 70 | Guys. Help me out here. What do I do about the location of my shifter now that I have the saginaw four speed tranny in my truck? The shifter comes up underneath my seat.
I really want to keep the stock look of my bench seat. I've thought about "looping" the shifter around the front of the seat and then curve it back up so the knob is directly above the shifter insertion point. That way I should still be able to push the shifer down to put it in reverse... right?
I'm desperate. I can either drive it tomorrow, or tear out the tranny and look for a T-5 and start over. PLEASE DON'T MAKE ME START OVER! Driving it tomorrow seems like a much better idea.
Thanks.
Mainjet | | | | | Joined: Mar 2007 Posts: 3,457 Crusty Old Sarge | | Crusty Old Sarge Joined: Mar 2007 Posts: 3,457 | There is a shifter that works for this. It mounts forward of the original location on the tranny and clears the seat. I saw it in Custom Trucks a few years back and kept the issue as I am using a Muncie. They actually ran a feature on the install for the shifter. The down side is that I'm in Iraq and not home with the magazine so I can't give you the name of the company. You should be able to contact Custom trucks and explain that your looking for the article and hopefully they can help you from there. I hope it works out for you, I can't wait to get back to work on my 59'. Good luck
~ Craig 1958 Viking 4400"The Book of Thor"Read the story in the DITY1960 Chevrolet C10"A Family Heirloom"Follow the story in the DITY Gallery'59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting) If you don't like driving yourTruck, you won't drive yourTruck..| Living life in the SLOW lane | | | | | Joined: Feb 2000 Posts: 364 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 364 | Check with Patrick's in Arizona...they sell a great shift lever that will work with the Saginaw. | | | | | Joined: Nov 2006 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 60 | I HAD A SETUP LIKE YOURS ONCE AND HAD A HURST SHIFTER WITH A HANDLE THAT WENT DIRECTLY FOREWARD SEVERAL INCHES AND THEN EXTENDED UP TO THE KNOB OR HANDLE AND THE STOCK SEAT DID NOT HAVE TO BE ALTERED IN ANY WAY, AND IT COULD BE SCOOTED FOREWARD FOR THE WIFE TO DRIVE TOO.WITH NO INTERFERRENCE. | | | | | Joined: Jan 2007 Posts: 70 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 70 | I had to take a break from the discussion, but made a shifter in the mean time. I bent a big 'U' into my shifter. It actually looks like the old "arrow through the head" that Steve Martin used to wear.
The seat fits where your head would go and shift knob is where your girl should be sitting (booo!), but it works and I didn't have to screw up my seat. I was worried about being able to push down for reverse, but it works fine. I wish I knew how to put the links into a message and I'd show you my 20 minute solution to what I thought was going to be a major problem. Been driving her ever since... Well until we got the sleet and snow today (darn this weather).
Thanks guys. | | | | | Joined: Feb 2006 Posts: 395 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 395 | as all have stated just modify something to work for your needs...doc | | | | | Joined: Feb 2007 Posts: 6 Junior Member | | Junior Member Joined: Feb 2007 Posts: 6 | GMCGUY is right I have a 4 speed sag and used a hurst with the forward config that works OK
cw
| | | | | Joined: May 2005 Posts: 145 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 145 | 73-75 Chevy Vegas with saginaws had floor mounted shifters. Ditto for 75-80 Monza. Maybe something like that would work? MV | | | | | Joined: Sep 2006 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 127 | I just got my patrick's catalogue... they have an install kit for the saginaw into a stovebolt... even a new floor panel to make it work...
"I'd rather have a bottle in front of me than a frontal lobotomy." -D. Parker 1951 Chevy 3100 | | |
