2 members (IHPWR, Otto Skorzeny), 147 guests, and 1 robot.
Topics128,157
Posts1,056,878
Members48,458
Page 1 of 3 1 2 3
#1375426 08/31/2020 6:42 PM
Hello all, new thread here for a new endeavor. First a little background:
I love my '48 1600 (3600 south of the border) and it's original 216 has always done me well. I'm also a realist and I know that nothing lasts forever. From the years on this site, I've learned that:
1- It's likely not worth the time and effort to rebuild a 216, should something go wrong
2- A full-pressure 235 and beyond are worth the extra dependability, HP and a relatively simple swap.
With this in mind, I've been watching for something to come up, local to me, but with no real pressure or timelines associated with it. I have yet to jump on anything, until just recently:
https://www.stovebolt.com/ubbthread...ne-code-starting-with-w.html#Post1371828
Needless to say, after finding the first Canadian Pontiac 261, I was hooked and quickly located and picked up a second one.
There are a number of good articles and discussions that define the American 261's that were mainly intended for big trucks, but the Canadian Pontiac story goes a little further.
In a nutshell, Pontiac Canada wanted something different for their cars, so they took the truck 261, added hydraulic lifters, a fiber cam gear cam out of a Corvette and did not add the full-flow oil filter.
This brings us to the present, where I have this engine sitting in my garage and no clue what to do with it grin
https://photos.app.goo.gl/PKRN2o6en3evxF15A
I can struggle through swapping engines and turning wrenches, but measuring clearances and identifying wear are not skills I currently possess. I would like to 'freshen-up' this engine and get it as reliable as possible. I also need to make some alterations to it to make sure it is compatible with my truck. I would like to do some of the work myself, and send it out for the work that I'm not comfortable in doing.
So to start off this thread (which will likely go on for some time), I was hoping to get some suggestions:
1 - What should I do to fully assess the condition of the engine as it sits?
2 - What actions do I need to add to the game plan to freshen this up?
Some specifics:
Engine ID: W9204502 - GM documentation says it is from a 1960 Canadian Pontiac, apparently it came out of a 1959 Pontiac.
Block: 3769717 - 261 for sure
Head: 3836848 - May not be original, but has higher compression! Steam holes may be an issue...
Thanks!
1948 Chevy Thriftmaster 3/4-Ton
Poncho "farming" in Ontario
Starting in the DITY
Continuing in the Project Journals
More images
There are only 10 types of people in this world, those who can read binary and those who can't.
I would say that some disassembly would be in order. You would want to measure cylinder wear to see if a rebore is necessary. It would be good to examine the bottom end too to see what is needed there. If you want to pay for a complete rebuild, a place like Parry Automotive could do that for you. I have used them to bore both of my 216s. By the way both my 216s are thriving in the respective vehicles.
1951 1 Ton Completed
Mike
If you're looking for things that need to be fixed, you're going to find them. Bring money.
Thanks Dragsix, I had read through that link, but I didn't know if I should start off that way, or run any tests (like compression) before I open it up. I'm not sure that I can clearly identify 'bad' scoring, but I will share pics here as I go and hopefully get some words from the wise wink I am especially curious to see if this head has the 'steam holes' for the 261 block, as the previous engine I bought did not and two of the cylinders were blown.
More images
two of the cylinders were blown?
I had 2 Pontiac 261's here ,a 56 and a 59 , both 848 heads and both had steam holes . I believe this was the norm for Canadian Pontiac 261 "s
good planning is no substitute for dumb luck
Panic, check it out: https://photos.app.goo.gl/f6Wiqx6P3Y5R1CQVA
John - that's encouraging to know. Any idea if they were original or added later? Others, more knowledgeable than I have said that they did not come with these heads originally.
More images
Pull the spark plugs, how do they look?
Run a compression check, and leak down. Pull the dip stick, what do you see?
If all is OK, change the oil, give it some gas and crank it!
Those cylinders look like they were full of water and broken by freezing. It's pretty unlikely the absence of coolant holes in the head had anything to do with it. Those "steam holes" are needed on the siamesed cylinders of engines like the 261 and the small block 400 V8 to promote coolant flow up the sides of the cylinders and prevent the formation of localized boiling where the coolant can't flow between cylinders.
Interesting suggestion Hodrod, that could very well be.
68ironhead, is it best to use the starter to test compression? I will mount it up if so.
More images
I've got a 235 engine that sat outside in the weather for several winters. The cylinders with intake valves open looked the same way- - - -badly rusted and cylinder walls utterly destroyed. I haven't magnafluxed the head yet, but there's a good possibility I'll find freeze damage there as well. I think the crankshaft and connecting rods, and the rocker arms and shafts can be salvaged. The rest of it is pretty much scrap iron.
Goach2 Both engines were complete when I got them and looked original and not like they were torn down , but I can't say for sure .
Also both engines still had the larger 261 carb, which leads me to believe they weren't messed with .
Deleted and updated this post below...
More images
You can put your photos directly in your thread.instructions are in the left margin of every page. Opening links is a PIA. Hey, it’s easy. Even a tech challenged person like me can do it. pix
More images
More images
The top of the cylinders has a carbon ring, perhaps just needs honing?
[img]https://www.stovebolt.com/ubbthread...umber/22127/filename/20200901_210243.jpg[/img]
[img]https://www.stovebolt.com/ubbthread...umber/22128/filename/20200901_210248.jpg[/img]
[img]https://www.stovebolt.com/ubbthread...umber/22129/filename/20200901_210256.jpg[/img]
This is what I have so far, now what? Send it out? Or is there something that I can do to determine the condition?
More images
Hone the cylinders lightly, then measure the taper using a piston ring, assuming you don't have a dial bore gauge or an inside micrometer. Sending an engine to a machine shop is like asking a personal trainer if you need to exercise- - - - -you're going to get the full treatment. That's how they make their living. Rebore the cylinders- - - -new pistons- - - -regrind the crankshaft- - - -new cam and lifters- - - -rework the cylinder head- - - -pretty soon, your checkbook is going to need CPR!
Well, too late for a compression check.
Parts look good so far.
Ironhead - I know frown I didn't feel like bolting on the flywheel, bell housing and starter. I really wanted to investigate the steam holes and I'm glad I did now smile
Hotrod - I agree, I'm only interested in 'freshening' this up, but I don't want to miss out on any opportunities to ensure dependability either. I have never honed any cylinders, I will have to look into what's involved.
More images
Am I looking to hone the whole cylinder? Or just the ridge at the top? I'm just wondering if I need a hone, or a ridge reamer...
More images
If there's a wear ridge at the top, not just carbon buildup, you'll need a ridge reamer. If it's just carbon, scrape it off and proceed with honing.
Maybe a stupid question, but from what I've read, you hone a cylinder after the pistons have been removed?
More images
Yes
Measure the cylinder taper first. That can be done with the pistons in place, since the majority of the wear happens within the first 2" or less of the top of the block. If there's more than about 5 thousandths of taper wear, a re-ring job will be pretty much a waste of time and money. Rebore the cylinders and install new oversize pistons. That gets into major overhaul territory.
Ok, so hone the top of the cylinders, not a reaming yet and get some measurements?
More images
You can measure in the areas just below the ridge. That’s what HRL is suggesting. Do this before you do any ridge removal to see what condition the cylinder is in. Removing the ridge just makes it easier to get the pistons out the top. Honing is done to even things up and provide a surface for the new rings to seat on. You can’t re-ring without taking the pistons out just as you can’t properly hone w/o taking the pistons out. HRL is telling you that reboreing and new pistons gets expensive. Read HRL’s post again slowly and follow his advice.
Yes, I'd rather not have to rebore. HRL's earlier post said hone then measure, so that's what I wanted to clarify. I may even have some inside calipers, have to look through my stuff...
More images
More images
The Full Monte gets expensive.
The piece of mind from going that route is priceless.
I am fortunate to have a machine shop which does top notch work and really cares about supporting crowds like ours. They make their money elsewhere, but they get their joy from helping us out.
Furthermore, the 261 is the envy of a lot of us, and I for one, would not like to hear about one flying apart from missing something due to lack of knowledge.
You'll only be able to measure the very top of the cylinder with that.
You need a true inside caliper
Dang! I fat-fingered the keyboard and lost several paragraphs of a reply! There is a detailed procedure on how to measure cylinder taper accurately with nothing but an old piston ring and a feeler gauge in John's tech tip on rebuilding his 261. Stand by- - - - -!
Try this method: https://www.stovebolt.com/techtips/engines/cylinder%20taper/index.html
Note: A ring running in a taper-worn cylinder at 2000 RPM is flexing 60 times per second, trying to maintain contact with the cylinder wall- - - -expanding and contracting in less than 2 inches of piston movement. It doesn't take long for the ring to lose its spring tension and stop sealing compression and/or oil.
Ok, so I will try and track down a caliper like that, but in the meantime, I do have one of these.
[img]https://www.stovebolt.com/ubbthread...umber/22149/filename/20200902_233825.jpg[/img]
So, if I understand the tech article, I would take off the top ring, put it in the cylinder, just under the top ridge, turn the crank so the piston goes to the top to keep it level, and then use feeler gauges stacked up to measure the gap.
More images
Yes, as long as the piston you've got out of the engine is the same size as the cylinder you're measuring. If one engine has a different bore size than the other, you might have a little difficulty measuring the end gaps. Once you measure the gap at the top, you'll need to push the ring down 2-3 inches to get the bottom gap measurement. What you're doing is measuring the difference in circumference of the cylinder walls at different levels and dividing the difference by Pi. (3.14, actually, but 3 is close enough). "Circumference = Pi X Diameter"- - - - -basic high school plane geometry with a practical application!
Don't be surprised if the rebuild total is 5 times the price of a running car...
My father seems to think I inherited a caliper like this from him. I am still looking, but I did come across this:
[img]https://www.stovebolt.com/ubbthread...umber/22161/filename/20200903_125807.jpg[/img]
Would this suffice?
More images
I give up!
BYE!
Ok, finally got a little time to pull out the piston ring and try these measurements. Put the ring at the top, just under the ridge:
[img]https://www.stovebolt.com/ubbthread...umber/22229/filename/20200905_134539.jpg[/img]
Stacking up the gap blades gives me this:
[img]https://www.stovebolt.com/ubbthread...umber/22230/filename/20200905_134919.jpg[/img]
Then rotated piston down to here:
[img]https://www.stovebolt.com/ubbthread...umber/22231/filename/20200905_135046.jpg[/img]
And gap showed:
[img]https://www.stovebolt.com/ubbthread...umber/22232/filename/20200905_135550.jpg[/img]
So the top gap measures out to 0.096" and the bottom to 0.085". which leaves a difference of 0.011"
Divided by PI that gives me 0.00367. From the tech articles, it looks like up to 0.005 is acceptable without reboring and new rings. I was going to try and do this with a caliper as well, but this seems to be pretty accurate in itself.
So now, I'm assuming I need to do this to all cylinders and if they all check out, then perhaps move on to the bottom end?
I also picked up one of these:
[img]https://www.stovebolt.com/ubbthread...umber/22233/filename/20200905_133735.jpg[/img]
Sorry, I ask a lot of questions, when it's something I've never done before. eek
More images
Ok, had time to check the rest of the cylinders, some were .005 or over, so I guess that puts this one at a rebore, with new piston territory, based on earlier comments. Is there any value in looking at the bottom end now? Based on some calls I've made, looks like I'm in the $4000-$5500 price range to shop it out.
This may have to sit in the corner for a bit...
More images
Page 1 of 3 1 2 3
