| | | Forums66 Topics128,089 Posts1,056,139 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2020 Posts: 1 Moderated | | Moderated Joined: Jul 2020 Posts: 1 | Hi, I am new here. First post. I have a 1954 GMC 1.5 ton. I replaced all my wheel cylinders and master cylinder, ordered all new parts and rebuilt my hydrovac, adjusted shoes, and bleed the complete brake system. I drove the truck a couple times and the brakes were good. I let it sit a couple weeks and had no brakes, master cylinder was now empty. i checked all lines and bleeders for leaks and couldn't find anything. re-bleed everything again, and the same thing happened. empty master cylinder. I removed the hydrovac, and expected to find the power cylinder assembly full from an internal leak. It was empty. Can someone give me some pointers on where I am losing brake fluid? Thank you. | | | | | Joined: May 2017 Posts: 330 'Bolter | | 'Bolter Joined: May 2017 Posts: 330 | Check the vacuum line from the booster to the manifold for fluid.
Park it indoors and lay dry cardboard under all the tires the booster, master and any joints with Tee or other fittings. Look for stains on the cardboard.
Get someone to hold the brakes down hard with the engine running to maximize the pressure in the system and trace all the lines for leaks.
Mac :{)
1962 K10 short step side, much modified for rally 1969 T50 fire truck, almost nos, needs a few things
| | | | | Joined: Apr 2009 Posts: 181 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 181 | Rusty, Another thought is to check your master cylinder. If the parts were mistakenly put in wrong, or if there is seepage around the cups, there could be enough leakage to cause noticeable fluid loss. One quick way to check this would be to pull the rubber seal back from the pushrod end of the cylinder and see if there is fluid inside, indicating leakage from that end of the cylinder.
1955 GMC 630, 1959 GMC W660, 1958 Chevy Spartan 80
