0 members (),
192
0
Mod | | | Forums66 Topics128,089 Posts1,056,143 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 25 Apprentice | | Apprentice Joined: Apr 2005 Posts: 25 | How close can I run the rear tires to the inner fender lip without rubbing? I am running leaf springs. | | | | | Joined: Feb 2007 Posts: 86 Member | | Member Joined: Feb 2007 Posts: 86 | It kinda depends on the combination of tire size/height and how loose your suspension is. What exactly do you have?
A short sidewall height will flex less and therefore have less tendency to sway toward the fender on turns or flex when you hit a bump. Also if your suspension is fairly tight you can get a little closer to the fender also.
For example, my wagon has polyeurathane bushings so it's good and stiff. I can barely fit a finger between the tire and fender and they haven't 'scrubbed' yet. Yet some other cars I've had were alittle worn out and would allow the rearend to travel and rub when I had as much as 3" clearance while standing still. | | | | | Joined: Jul 2004 Posts: 427 Shop Shark | | Shop Shark Joined: Jul 2004 Posts: 427 | No less than a 1 in. Even that may rub under hard cornering. The installation of pan hard bar will help keep the rear from moving. | | |
