7 members (dt235sd, 3B, frogfarmer, 1955 1 Series, Bruce 1954-4100, DennisM, 1 invisible),
88
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,074 Posts1,055,910 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 171 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 171 | Hello, yesterday I dismantled my rear axle. I took off the wheel housing and saw that a seal is probably defective. It is called National 55511S My question is where can I get this and how do I dismantle it? If you like to have a look, see here: https://www.kripahle-online.de/unterricht/?page_id=2408The last pic will show you the part what i mean. Wolfgang | | | | | Joined: Dec 2014 Posts: 357 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 357 | National 55511S would surely appear to be a sealed bearing. Why someone would utilize a sealed bearing inside the rear end??? Any bearing shop or big parts house. Now the parts house will have a kit that has all the seals and bearings.
Julian Carter
1970 Triumph GT6 1967 Triumph TR4A 1952 Chevy 3600 1948 MG-TC
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy wokri the seal part number I come up with for a 1953 Chevrolet 3600 rear hub seal is National 2081, hope that helps. | | |
