1 members (Forty9), 66 guests, and 1 robot.
Topics128,055
Posts1,055,782
#1374839 08/25/2020 10:03 PM
PA OUTLAW
PA OUTLAW
Hello I have a 1954 chevy 3100 have question about the gas tank. Were the filler tube and the vent tube go into the tank there are 2 bolt's .Is there a gasket under that flange ? Reason being having tanked cooked out at raditaor shop.and need to know if I will need to replace gasket or Oring or what THANK YOU for any help or advice thanks again!!!!
jrhackett #1374891 08/26/2020 11:07 AM
Do you have a pic of that flange?
1949 5 Window 3100
Follow in the DITY
Veteran of the USAF
My Website
jrhackett #1374916 08/26/2020 3:45 PM
PA OUTLAW
PA OUTLAW
No I don't tank at radiator shop were the fill tube enters tank
jrhackett #1374938 08/26/2020 5:32 PM
I believe that flange is soldered in place, in addition to the two bolts. With the thin metal of the flange, it would be difficult to get a gasket to seal well. I think the bolts were there just to hold the neck in place while flowing solder into the joint. I can't get a close look at my tank, but I recall seeing it being soldered.
[on edit] Just to clarify: I didn't actually see it BEING soldered (I would have been 3 years old then, and they probably wouldn't have let me in the assembly plant), but I do remember seeing solder around the edges of the flange, when I removed it from the truck. wink
jrhackett #1374976 08/27/2020 2:44 AM
Curmudgeon
Curmudgeon
A picture of my new Spectra tank. Built like the old tanks. It's bolted and soldered.
