| | | Forums66 Topics128,108 Posts1,056,231 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2016 Posts: 148 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 148 | Tony, I recently found this site that might help with some of your questions. He also has a youtube channel: Turbo 250
-David
1953 2-Ton GMC
| | | | | Joined: Feb 2004 Posts: 29,803 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,803 | Putting a turbo on an engine that hasn't been designed for it from the drawing board up isn't likely to be successful. Look at some turbo and non-turbo models of the same engine, such as the Toyota Supra inline six. Very few parts interchange between the two engines, even though they share the same displacement and appearance. Packing 10 pounds of potatoes into a 5-pound sack usually isn't a good idea, either! Jerry
| | | | | Joined: Jul 2019 Posts: 559 'Bolter | | 'Bolter Joined: Jul 2019 Posts: 559 | I do it regularly. Ive safely taken bone stock 200k mile motors and made over 500hp reliably. Its 2020. We have the technology and know how to do this stuff now. I cant speak for the old straight 6 variants durability of hard parts but i would try it. | | | | | Joined: Dec 2017 Posts: 1,652 'Bolter | | 'Bolter Joined: Dec 2017 Posts: 1,652 | Tom Lowe over at 12bolt.com has done it and used pretty common parts to do it. I want to say its been 10 years since he first did it to an el camino. Call him. He is a real enthusiast, makes a lot of parts for our inline motors, is easy to talk to and quite knowledgeable. You will like him.
Mike
