Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (Otto Skorzeny, 2-Ton, Hanks custodian, 55shaker), 124 guests, and 5 robots.
Topics128,281
Posts1,058,484
Members48,490
#1374812 08/25/2020 7:27 PM
I got a 50 with a 261ci, 12 volt conversion and alternator. It died when I was stopped at an intersection the other day. When I tried to restart it, the battery was dead. It started just fine before I left and it was running perfect then it died and I could not restart it. I changed the points and the fuel filter less than 100 miles ago. Does any one have any suggestions on what the problem might be? I am thinking it might be the alternator, based on the fact the battery was dead, and it should have been charging.
Mike
I would charge the battery, then test the alternator output (volts and amps) while the truck is running.
Another quality post.
Real Trucks Rattle
Moderator
Moderator
2 Online: Content
Simple check!
When you have the engine running, unhook a battery cable.
If the engine dies, it's the alternator.
If it stays running running, it the battery.
Since it is a 1950 that has been changed to 12V, there could also be a wiring issue. Ground!
Don
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
Unhook the cable- - - - -then go buy an alternator. That test works- - - -sort of- - - -on generator-equipped vehicles. Solid state rectifers and voltage regulators really don't like the 100+ volt spike that happens just as the cable gets disconnected from the battery. A battery acts somewhat like a shock absorber in a charging system- - - -helping to dampen out sudden surges from things like solenoid contacts making and breaking, and other voltage surges. Parts dealers love it when people repeat "old mechanics' tales" that went obsolete decades ago, like "Keep a hot engine running while you pour water into it"- - - -that one quit being relevant when they put a water pump on the Model A Ford in 1928.
