2 members (Danielbolt, Steelonsteel), 82 guests, and 3 robots.
Topics128,095
Posts1,056,492
Members48,444
Fixer of Things I Probably Broke
Replacing my 12v coil (stamped with "Use only with external resistor") and ballast resistor (which exists) on a '53 235 but am confused as to which resistor to get?
Autozone has a few:
https://www.autozone.com/ignition/ballast-resistor/duralast-ballast-resistor-f795/118802_0_0
https://www.autozone.com/ignition/ballast-resistor/duralast-ballast-resistor-al795/111120_0_0
https://www.autozone.com/ignition/ballast-resistor/duralast-ballast-resistor-dr794/116673_0_9348
They range in resistance from 0.633 to 1.8 Ω.
How do I know which one to use on my system?
And at the same time, are all 12v coils created equal?
Warning, I go cross-eyed reading the many excellent threads detailing how to calculate this and that and amps and ohm-mygoodness it's all over my head... so break it down like I'm five?
1953 Chevy 3100 Frankentruck with 235 and mostly original bits.
3B Offline
Hy ThreeTree53, what I did to check which of the Autozone resistors is appropriate was I identified what I was working on to the Autozone website, I used a 1956 Chevrolet 3100 pickup, as 12 volts didn't start to be used until 1955, I used 56 just to be sure they were 12 volt. The first two on the list came up as does/will NOT fit your vehicle, the third resistor p/n DR794 DOES fit your vehicle.
As to your coil question, no not all 12 volt coils are created equal, to begin with there are coils that are designed to work without external resistors, also all different outputs are available. If you went into Autozone and told them you would like to purchase an ignition coil to fit a 1956 Chevrolet 1/2 ton (3100) with a six cylinder engine, they would sell you an ignition coil appropriate to replace your original coil, hope that answers your questions.
Quite common to have to be a bit knowledgeable and also sneaky when dealing with the parts stores. 3B has it nailed. Just fudge a few years to get into a range where parts work.🛠
@3B Awesome! That's a good lead (the year thing started switching to 12v) thanks for the tip and the info.
Moderated
Moderated
Hello...you can't "short" a counterbalance to short of what it was initially constructed. In the event that your meter checks it at zero, it's acceptable. This is on the grounds that they are a wire wound obstruction. There is just no chance that they can FAIL with generously less obstruction than they were fabricated with.
Generally, a counterweight either comes up short "open" or "discontinuous," IE it's messed up inside and reaches a portion of the time.
flex circuit design for manufacturability guide
My coil says "No External Resistor Required." Made life easier. I probably got it at NAPA.
What part number NAPA coil?
Insomniac
Insomniac
Internal vs external ballast resistors has been debated before. No clear winner, IMO.
Here's a thread with NAPA part numbers quoted: https://www.stovebolt.com/ubbthreads/ubbthreads.php/topics/998130/1.html
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Mine is a 12V Echlin, 905. Installed in 2007. No complaints.
