1 members (baldeagle),
158
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | A friend in the lower 48 called me and wanted help. They have to move a 54 Chevy 3/4 ton pickup that has sat for 30 years, all tires flat. I told him to try air first, maybe some will hold. My question is what other wheels might fit right on there to get him out of the spot? What he has are 8 lug, could they be split rim? I could not answer these questions, please help! Dave 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Ford, Dodge, Toyota, etc. how far does he have to move it? Flatbed trailer rent or borrow, would not have to get and wheels and tires.
Ed
| | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Apr 2016 Posts: 102 'Bolter | | 'Bolter Joined: Apr 2016 Posts: 102 | They should be 8 lug on 6.5" diameter circle. All dodges still run these. Chevy ran them up to 2011, ford ran them til 1999. A lot of trailers still run them. It should not be hard to find something at a junkyard, friend's spare,...
Jon | | | | | Joined: Aug 2020 Posts: 79 'Bolter | | 'Bolter Joined: Aug 2020 Posts: 79 | https://www.amazon.com/Silver-Trailer-Radial-Mounted-circle/dp/B00AU9I7CE/ref=sr_1_1?crid=3IR7FJKBYHH7O&dchild=1&keywords=8+lug+trailer+wheels&qid=1597275282&sprefix=8lug+trailer+%2Caps%2C203&sr=8-1
These trucks had 1/2” studs and the newer trucks are 9/16 or 14mm stud. Trailer wheels for 7k lb axles have smaller stud holes.
Pat 1940’s tech was great in the 40’s
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Nobody mentioned that airing up old split rim tires can be very dangerous. | | | | | Joined: Nov 2000 Posts: 1,969 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,969 | A 54 Chevy 3/4-ton wheel is not technically a split rim. That said, caution should be used airing up one with a flat tire, if the detachable rim (ring) has come unseated from the wheel. I would suggest jacking it up to get the weight off before inflation. Is the goal to get it on a trailer?
Professional Novice
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Dec 2014 Posts: 678 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 678 | Just call a tow truck, preferably a slide-back with a winch.
1951 Chevy Panel Truck
| | | | | Joined: Oct 2019 Posts: 19 'Bolter | | 'Bolter Joined: Oct 2019 Posts: 19 | It should be mentioned that while many 8 lug 6.5" wheels will bolt up, an offset may cause interference with the tie rod ends. You need a wheel with little or no offset or the front wheel can not seat. I've read that some Ford van wheels will work. I'm using newer GM wheels with 1-1/2" deeps adapters (shims) temporarily on the front until I can find a set of more suitable wheels. | | | | | Joined: Jan 2020 Posts: 620 'Bolter | | 'Bolter Joined: Jan 2020 Posts: 620 | I hate split rims, two personal accounts of men being killed or maimed by them. My dad in 1968 refused to have any of his employees mount tires or even air up the tires of old or new split rims. He was one of the first to have a cage then after several weeks cut the whole rig up. I'm a big history and authentic fan. When it comes to items that kill or maim a person only pictures of the item or a dismantled one will be shown in my museum. I'm sure the old timers had safe guards (somewhat), but it's not worth the risk. Doc.
