3 members (Danielbolt, bluechev, 1 invisible), 104 guests, and 1 robot.
Topics128,157
Posts1,056,875
Members48,456
I lifted the truck up and and put the truck in gear to see what happens. One the drivers side spins. the other side just jumps a tiny bit when i first let out the clutch... other wise stays still. i would think the other side should spin in reverse on this. junk rear end in my truck?
Sounds like an open diff. They can spin either side equally or at different rates.
Crusing in the Passing Lane
How does it do with both wheels on the ground?
Ed
i have not tried to let the clutch out on the ground yet. no brakes at this time. The drivers side spins in neutral really easy. the passenger side is pretty tight. i can spin it my hand but it not easy.
Are the brakes dragging on the passenger side?
Pat
1940’s tech was great in the 40’s
i dont think its brakes. if i can turn it over by hand ( even if its hard) i would think the engine power would for sure move that tire
7
7 Offline
Brake is tight on the passenger side, the driver side spins with the engine running due to the wheel with the least resistance , sounds like the differential is working ok. Time to pull the drums.
Dont sound like its to far from normal. Pull drums and diff cover. See what cha got.
looks like is was the brake.
thumbs_up
