1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 29 Apprentice | | Apprentice Joined: Feb 2006 Posts: 29 | in my wisdom i have got myself a 1956 265 motor for my 51.after reading the david vizard book it seems i have got an odd block!he states that there is a threded hole by the oil filter for the clutch pivot ball.some also had one near the freeze plug.mine dosent appear to have any.do i need this pivot point if i use the orignal gearbox.will i have to change the bellhouseing?cheers jonathan | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | Jon, To the best of my knowledge the pivot ball was only used on car applications prior to about 63. You will need a V-8 bellhousing and your existing clutch linkage should work. However, make sure that the V-8 bellhousing will match up to your existing rear crossmember. Fred
| | | | | Joined: Feb 2006 Posts: 29 Apprentice | | Apprentice Joined: Feb 2006 Posts: 29 | cheers fred.the search is on for a bellhousing!  | | |
