5 members (Shaffer's1950, Cosmo, Gdads51, dt235sd, baldeagle), 259 guests, and 3 robots.
Topics128,088
Posts1,055,993
Members48,430
#137448 03/13/2007 10:18 PM
Apprentice
Apprentice
in my wisdom i have got myself a 1956 265 motor for my 51.after reading the david vizard book it seems i have got an odd block!he states that there is a threded hole by the oil filter for the clutch pivot ball.some also had one near the freeze plug.mine dosent appear to have any.do i need this pivot point if i use the orignal gearbox.will i have to change the bellhouseing?cheers jonathan
#137449 03/14/2007 3:38 AM
Jon,
To the best of my knowledge the pivot ball was only used on car applications prior to about 63. You will need a V-8 bellhousing and your existing clutch linkage should work. However, make sure that the V-8 bellhousing will match up to your existing rear crossmember.
Fred
#137450 03/14/2007 8:42 AM
Apprentice
Apprentice
cheers fred.the search is on for a bellhousing! smile
