4 members (Stovebolt48, Steelonsteel, Bill Hanlon, lumbersawyer), 31 guests, and 2 robots.
Topics128,037
Posts1,055,466
Members48,422
#1374343 08/21/2020 11:18 PM
The more I read, the more confused I get, lol. I was thinking about switching out the 216 in my '46 truck for something a little more modern but close enough looking to the original, so a 236 or 261 seemed like the answer. Most of the ones I'm finding are in need of rebuilding but I'm getting number on rebuilds in the $3,500 + range. And that's assuming the block and head have no cracks. The prices I'm getting for the rebuild of the 216 are about the same, and that includes replacing the babbets with bearings. Now I've found a 235 that allegedly has been rebuilt. The casting numbers of the block is 3835911 and the head is 3836848. According to Advanced Design.com that block number was either a '53, '54 or '55 Corvette, a '54 truck, or a '55 car. The head was a '56 or later head. According to the current owner it was in a '54 truck and it runs. It's less than half of what they're asking for a rebuild so perhaps this might be the better way to go.
Any tips or suggestions?
Joe
1946 Chevy 3/4 Ton Flatbed
Tearing her down
Story in the DITY Gallery
More images
The price being quoted for rebuilding is about on par for today’s machine shops. Way overpriced for a “Unknown Quality”, used, rebuilt engine. You should be able to pick up a running 235 for less than $1000 that you can do compression tests on before you buy it. JMO🛠
Without disassembly or assembly (so machine work, parts - grading from stock components - valves, pistons, cam, etc, etc) I probably have about 3k in my 292 rebuild. So that doesn't seem too far off a top to bottom build.
Too many shops will replace everything they can find, whether you need it or not.
Thanks Don. I'm going to see where that guy lives and maybe take a look at it this weekend. I'll try and see the other "rebuilt" one too and see if they're worth what the owners are asking.
One of the local rebuilders I've found said he'd check out the 216 block and head for cracks or any other flaws that would make it not rebuildable for about $100. I think I'm going to do that since I'm going to remove it anyway to do the rest of the work.
Joe
Tearing her down
More images
I was quoted at 2k for a complete 261 rebuild in San Antonio. Most of which is parts.
Chris
Keep asking, and pretty soon somebody will toss out a number you want to hear. Of course, it will be a total WAG, but that doesn't matter- - - - -internet advice is worth exactly what if costs you to read it! I can "rebuild" a stovebolt engine with a cost of anywhere from a few hundred dollars to a few thousand, depending on what I want to claim is a rebuilding job. If you're a real cheapskate, I can do it for the cost of a few cans of spray paint!
Marks on the crank journals that you can't feel with your fingernail, rust spots that didn't clean up with the hone but are below the ring travel, the stock oil pump, hardened valve seats, rockers with no visual damage and tight on the shaft: these are frequently good enough to leave alone.
If you're told you need main caps, line boring, sleeves, etc: find a different core.
62401
Joe,
Just some food for thought, having lived your dream now through 3 trucks needing engine work... My first was the '39 with the seized 216. So I had that completely rebuilt (babbit and all) that ran about $4,000 by the time I stopped writing cheques. And that was back in '92. Not sure what that would have been in today dollars. At the time, the old timers who did it told me upfront that being a babbit pounder added $1,000 to the rebuild. Anyway, it was a beautiful engine and ran perfectly. But it was still a babbit pounding 216 that absolutely screamed like it was about to come apart at anything over 45 MPH.
Next up was a '49 (my second frame off resto). I removed the 235 that was in it and had it rebuilt very professionally. This was about 10-15 years ago. Again, the completed price tag was over the $4k mark. Again, a beautifully running engine.
Current truck (the '49 1-ton) had a nice running 216 in it (low-mileage truck that came from a family friend). But .... still a babbit pounding 216. The truck was not suitable for any driving beyond the county line. This time, I skipped the 235 route and went straight to the 261. Not sure what I have in that one, but it was a group effort (led by Hotrod lincoln!) anyway and we made a get-together, workshop and tech tip out of the whole thing (check out "Rebuilding the 261" in our Tech Tips section). I was able to use most of the peripherals from the 216. And I got the kit from Jim Carter to use the 216 valve cover. I was lucky to get a '54 261, so the water pump/fan is in the right location, so no adapter plates, radiator relocation or any modifications required to slip the 261 in there. Meaning that today, when you look in my engine bay, only a Stovebolt Geek would be able to tell that it isn't the original 216 staring back at you. But yet I can cruise in traffic and do 60-65 on the highway all day long with a useful load in the bed. And my truck has the 9-foot bed, too smile
What I learned from all of this:
1. Originality or Driveability -- pick one
2. If you go with driveability, do not waste time, money or effort on a 216. Cubic inches are your friends and the more, the merrier. To keep close to original, stick with a straight six like a 235 or 261. A GMC 302 would be the nuts, but there is some work to do in fitting it into a non-GMC of an earlier vintage like yours. But still ...
3. Think of any unknown (to you personally) engine as a rebuildable core only, nothing more. Hotrod Lincoln taught me that and it is absolutely true. You will hear anecdotes from people who stumbled across freebies that ran perfectly ... for awhile. Most of those stories don't include the year or two later post script... I was once given a "Recently rebuilt, low mileage engine" that I happily installed as was and it ran great ... for awhile. Until an expert listened to it once (um, that would be ... Hotrod Lincoln!) and said, "You have to pull that engine and rebuild it" so we did and sure enough, the people who rebuilt it neglected to address scoring in the crankshaft journals or the piston that was missing a chunk ... Who knows when that engine would have failed catastrophically? So sure, you can run an engine as you find it, but you are betting against the house and you know how *that* goes ...
4. If you are going for an upgrade, go all in. Rebuild whatever you get and go big early because if you don't, you'll wish you had later. A 261 is a good choice for max power in the most form/fit replacement package. A 235 is second. Rebuilding your original 216 is a great option if you want to maintain originality -- but you might still want to talk to Hotrod LIncoln off line as he is cooking up a plan for rebuilding 216's to be as powerful as a 261 (or better). If you go this route, you might be able to retain originality while gaining driveability. But affordability may go out the window -- be prepared to load up the dollar gun and flip the selector switch to full auto.
Hope any of this helps ... or even makes sense.
Regards,
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Thanks for the kind words, John! I was very fortunate to grow up in the company of folks who fed their families and paid the mortgage by keeping Babbit-pounder stovebolts running- - - -back when a professional-quality "in the frame" ring and valve job cost the princely sum of $125.00. The shade tree wrench jockeys did it for $75.00 or so!
Just as an aside- - - -the machine work alone on the crankshaft for that "261 that looks like a 216" is going to cost me around $450.00, done by an old geezer who has a couple of years on me and specializes in making stroker crankshafts for antique tractor pull engines. That's the main reason I just bought my own crankshaft grinder! By the time that one's up and running on the dyno, I'll have $4K or more just in parts and machine work, and enough labor time to build three engines the way we did your 261.
Fun and games, guys- - - -"We do the difficult stuff every day- - - -the impossible just takes a little longer!"
