2 members (Shaffer's1950, 1 invisible),
36
Mod | | | Forums66 Topics128,035 Posts1,055,443 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 216 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 216 | The more I read, the more confused I get, lol. I was thinking about switching out the 216 in my '46 truck for something a little more modern but close enough looking to the original, so a 236 or 261 seemed like the answer. Most of the ones I'm finding are in need of rebuilding but I'm getting number on rebuilds in the $3,500 + range. And that's assuming the block and head have no cracks. The prices I'm getting for the rebuild of the 216 are about the same, and that includes replacing the babbets with bearings. Now I've found a 235 that allegedly has been rebuilt. The casting numbers of the block is 3835911 and the head is 3836848. According to Advanced Design.com that block number was either a '53, '54 or '55 Corvette, a '54 truck, or a '55 car. The head was a '56 or later head. According to the current owner it was in a '54 truck and it runs. It's less than half of what they're asking for a rebuild so perhaps this might be the better way to go.
Any tips or suggestions?
Joe | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | The price being quoted for rebuilding is about on par for today’s machine shops. Way overpriced for a “Unknown Quality”, used, rebuilt engine. You should be able to pick up a running 235 for less than $1000 that you can do compression tests on before you buy it. JMOðŸ›
| | | | | Joined: Jan 2000 Posts: 591 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 591 | | | | | | Joined: Jul 2013 Posts: 388 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 388 | Without disassembly or assembly (so machine work, parts - grading from stock components - valves, pistons, cam, etc, etc) I probably have about 3k in my 292 rebuild. So that doesn't seem too far off a top to bottom build. | | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | Too many shops will replace everything they can find, whether you need it or not. | | | | | Joined: Jul 2013 Posts: 216 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 216 | Thanks Don. I'm going to see where that guy lives and maybe take a look at it this weekend. I'll try and see the other "rebuilt" one too and see if they're worth what the owners are asking.
One of the local rebuilders I've found said he'd check out the 216 block and head for cracks or any other flaws that would make it not rebuildable for about $100. I think I'm going to do that since I'm going to remove it anyway to do the rest of the work.
Joe | | | | | Joined: Jan 2013 Posts: 2,232 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,232 | I was quoted at 2k for a complete 261 rebuild in San Antonio. Most of which is parts.
Chris
| | | | | Joined: Feb 2004 Posts: 29,749 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,749 | Keep asking, and pretty soon somebody will toss out a number you want to hear. Of course, it will be a total WAG, but that doesn't matter- - - - -internet advice is worth exactly what if costs you to read it! I can "rebuild" a stovebolt engine with a cost of anywhere from a few hundred dollars to a few thousand, depending on what I want to claim is a rebuilding job. If you're a real cheapskate, I can do it for the cost of a few cans of spray paint! Jerry
| | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | Marks on the crank journals that you can't feel with your fingernail, rust spots that didn't clean up with the hone but are below the ring travel, the stock oil pump, hardened valve seats, rockers with no visual damage and tight on the shaft: these are frequently good enough to leave alone. If you're told you need main caps, line boring, sleeves, etc: find a different core. | | | | | Joined: Nov 1995 Posts: 5,714 62401 | | 62401 Joined: Nov 1995 Posts: 5,714 | Joe, Just some food for thought, having lived your dream now through 3 trucks needing engine work... My first was the '39 with the seized 216. So I had that completely rebuilt (babbit and all) that ran about $4,000 by the time I stopped writing cheques. And that was back in '92. Not sure what that would have been in today dollars. At the time, the old timers who did it told me upfront that being a babbit pounder added $1,000 to the rebuild. Anyway, it was a beautiful engine and ran perfectly. But it was still a babbit pounding 216 that absolutely screamed like it was about to come apart at anything over 45 MPH. Next up was a '49 (my second frame off resto). I removed the 235 that was in it and had it rebuilt very professionally. This was about 10-15 years ago. Again, the completed price tag was over the $4k mark. Again, a beautifully running engine. Current truck (the '49 1-ton) had a nice running 216 in it (low-mileage truck that came from a family friend). But .... still a babbit pounding 216. The truck was not suitable for any driving beyond the county line. This time, I skipped the 235 route and went straight to the 261. Not sure what I have in that one, but it was a group effort (led by Hotrod lincoln!) anyway and we made a get-together, workshop and tech tip out of the whole thing (check out "Rebuilding the 261" in our Tech Tips section). I was able to use most of the peripherals from the 216. And I got the kit from Jim Carter to use the 216 valve cover. I was lucky to get a '54 261, so the water pump/fan is in the right location, so no adapter plates, radiator relocation or any modifications required to slip the 261 in there. Meaning that today, when you look in my engine bay, only a Stovebolt Geek would be able to tell that it isn't the original 216 staring back at you. But yet I can cruise in traffic and do 60-65 on the highway all day long with a useful load in the bed. And my truck has the 9-foot bed, too  What I learned from all of this: 1. Originality or Driveability -- pick one 2. If you go with driveability, do not waste time, money or effort on a 216. Cubic inches are your friends and the more, the merrier. To keep close to original, stick with a straight six like a 235 or 261. A GMC 302 would be the nuts, but there is some work to do in fitting it into a non-GMC of an earlier vintage like yours. But still ... 3. Think of any unknown (to you personally) engine as a rebuildable core only, nothing more. Hotrod Lincoln taught me that and it is absolutely true. You will hear anecdotes from people who stumbled across freebies that ran perfectly ... for awhile. Most of those stories don't include the year or two later post script... I was once given a "Recently rebuilt, low mileage engine" that I happily installed as was and it ran great ... for awhile. Until an expert listened to it once (um, that would be ... Hotrod Lincoln!) and said, "You have to pull that engine and rebuild it" so we did and sure enough, the people who rebuilt it neglected to address scoring in the crankshaft journals or the piston that was missing a chunk ... Who knows when that engine would have failed catastrophically? So sure, you can run an engine as you find it, but you are betting against the house and you know how *that* goes ... 4. If you are going for an upgrade, go all in. Rebuild whatever you get and go big early because if you don't, you'll wish you had later. A 261 is a good choice for max power in the most form/fit replacement package. A 235 is second. Rebuilding your original 216 is a great option if you want to maintain originality -- but you might still want to talk to Hotrod LIncoln off line as he is cooking up a plan for rebuilding 216's to be as powerful as a 261 (or better). If you go this route, you might be able to retain originality while gaining driveability. But affordability may go out the window -- be prepared to load up the dollar gun and flip the selector switch to full auto. Hope any of this helps ... or even makes sense. Regards, John
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Feb 2004 Posts: 29,749 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,749 | Thanks for the kind words, John! I was very fortunate to grow up in the company of folks who fed their families and paid the mortgage by keeping Babbit-pounder stovebolts running- - - -back when a professional-quality "in the frame" ring and valve job cost the princely sum of $125.00. The shade tree wrench jockeys did it for $75.00 or so!
Just as an aside- - - -the machine work alone on the crankshaft for that "261 that looks like a 216" is going to cost me around $450.00, done by an old geezer who has a couple of years on me and specializes in making stroker crankshafts for antique tractor pull engines. That's the main reason I just bought my own crankshaft grinder! By the time that one's up and running on the dyno, I'll have $4K or more just in parts and machine work, and enough labor time to build three engines the way we did your 261.
Fun and games, guys- - - -"We do the difficult stuff every day- - - -the impossible just takes a little longer!" Jerry
