5 members (carbking, 55shaker, moparguy, Gdads51, 2-Ton), 277 guests, and 3 robots.
Topics128,162
Posts1,057,047
Members48,463
The extremely hard to find S10 T5 tail housing with the cable speedo connection is now being produced in the aftermarket. I just saw this on eBay with 4.8/5 stars on the review. Price is under $250 delivered. This is good news indeed.
IMPORTANT! You will still need an S10 case cover to make it work. Plus, you will need to install a drive gear on the T5 main shaft. Just so you know.
You can bypass EPAY, and go direct to Dan Conley 369 910 6942, fast turn around, you send your tail housing and rear end gear info. Got mine done in a week--Bill
Does Dan sell the aftermarket tail housing or does he modify your VSS style tail housing?
You send your tail housing--he modifies..Bill
