| | | Forums66 Topics128,086 Posts1,056,331 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2020 Posts: 79 'Bolter | | 'Bolter Joined: Aug 2020 Posts: 79 | Is there a more modern front hub with 9/16” studs that adapts to the 49 spindle? Bonus if it increases track width too.
Pat 1940’s tech was great in the 40’s
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | What is the problem with the old hubs? | | | | | Joined: Feb 2004 Posts: 29,825 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,825 | It would probably be possible to adapt a later model spindle to the existing kingpin mounts. We used to install a 3/4 ton Ford rear axle load tube to the right front hub and run a "wide 5" front wheel and brake on the dirt track cars. A good machinist and welder could probably do something similar with a 3600 steering knuckle assembly. I'd probably cut off the existing spindle, bore a hole in the steering knuckle, and fabricate an appropriate-sized spindle from bar stock and press and weld it into place. Another method would be to turn the existing spindle down to a straight contour and press a fabricated spindle over it, then make a weld back at the steering knuckle. Difficult, but not impossible! Jerry
| | | | | Joined: Aug 2020 Posts: 79 'Bolter | | 'Bolter Joined: Aug 2020 Posts: 79 | It would probably be possible to adapt a later model spindle to the existing kingpin mounts. We used to install a 3/4 ton Ford rear axle load tube to the right front hub and run a "wide 5" front wheel and brake on the dirt track cars. A good machinist and welder could probably do something similar with a 3600 steering knuckle assembly. I'd probably cut off the existing spindle, bore a hole in the steering knuckle, and fabricate an appropriate-sized spindle from bar stock and press and weld it into place. Another method would be to turn the existing spindle down to a straight contour and press a fabricated spindle over it, then make a weld back at the steering knuckle. Difficult, but not impossible! Jerry It would be easier just to turn some custom hubs.....
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy AwDang, Is your truck currently the single wheel version? If it is the single wheel version, you could swap dual wheel hubs onto the front, that would increase your track dramatically, maybe even too much. | | | | | Joined: Aug 2020 Posts: 79 'Bolter | | 'Bolter Joined: Aug 2020 Posts: 79 | Hy AwDang, Is your truck currently the single wheel version? If it is the single wheel version, you could swap dual wheel hubs onto the front, that would increase your track dramatically, maybe even too much. Hum....gotta look into that. 3800 dually front hubs?
