6 members (3B, Gdads51, Tinker5, Bill Hanlon, Bills Auto Works, WICruiser), 141 guests, and 3 robots.
Topics128,195
Posts1,057,378
Members48,469
I'm running a 350 in this truck, and although I'm sure the 3-row might run a little cooler, I don't want to pull the trigger on one if the 2-row is perfectly fine.
I'm looking at aluminum ones, so I'd have to think they run cooler than OEM anyway, right?
Thanks in advance!
1957 Chevy Panel Truck, powered by SBC 350 from 1977 Camaro
Author, Bring CHANGE Into Your Life (a truly easy investment tool)
https://www.amazon.com/Bring-CHANGE-Into-truly-investment/dp/1077276869
I run a 4 row aluminum radiator in my ‘62 C-10. Not much physical difference and bolted in in the original holes. I’m running a built 350 W/700r4. Runs around 185 in the summer months.
Moderator, Electrical Bay
Aluminum will dissipate heat faster in my experience. I have a 3 row with a 235 with custom shroud and Spal 2020 cfm fan.
~ Jon
Thanks, guys!
What did you end up going with? I’m looking for one righ now as well.
I have not yet bought one bc I'm going crazy with the shopping for one. Here's why:
1. I was hoping to get one made in the US- many are made in China. Apparently, US ones are made with 1" tubes where Chinese ones are made with 1/2" tubes.
2. I am still not sure if I should go with 2-row or 3-row. It's not a high power engine, it's under 300HP, so I'm guessing 2-row would be ok.
3. I'm trying to spend no more than $300
I need to pull the trigger by tomorrow, I just wish the decision-making process wasn't so tough.
I'm probably going to go with this one:
https://www.summitracing.com/parts/sum-384039/make/chevrolet
Reasons are:
1. it will be here by Friday
2. it's polished for no extra fee
3. it's a 3-row, for the same price as what others are charging for 2-rows
Mike
Originally Posted by Dragsix
Thanks!
I pulled the trigger and bought the one from Summit. It should be here by Friday. I'll post pics once installed if anyone wants/needs to see.
PM
Would you post a pix of the installed radiator. I’m putting a 350 in my 59 3600 and haven’t decided on a radiator yet.
56 210 Del Ray
68 Camaro BB
68 Mustang Convertible
68 Olds Cutlass Convertible 442 clone with 455
74 Dodge Charger with 440 swap
59 Apache 3600 dually Tow Truck
Aluminum is a poor substitute for copper in terms of heat dissipation, so go bigger, not smaller when going that route. I'd suggest 3 row as a minimum, and 4 if it can be squeezed into the budget. What's more expensive, a radiator or an engine?
Oh Yes, just took a three row aluminum out of our 34 Dodge Brothers p/u with a max wedge 440. Would not handle the job, got a very good 4 row brass and copper from a 46 Chevy two ton. Everything is good in Ed's Happy Land. Doc.
Here are pics:
