3 members (Gib70, Hawkman, Hanks custodian), 125 guests, and 3 robots.
Topics128,052
Posts1,055,774
#1373253 08/13/2020 11:10 PM
I have a 1969 C60 that I have been very slowly been working on and gathering parts for when I get time. I just replaced the 20" rims and tires today with new 22.5" Daytons and 295/75s. All was good and great after only breaking one stud until I got to the drivers side steer tire. The tire spun just a little and I figured I would work it back and forth to get it to break free with no luck. I ended up locking it in solid by hand and can't get it to move. I put the tire on and aligned it the best I could based off of rim/hub distance until I can figure out why it's not spinning.
It has air brakes obviously and this is my first truck with air brakes. I have only driven this truck about 5 miles in the past year or so. It's been driven maybe 1/4 mile in the last 2 weeks and didn't show any signs of a sticking tire. It has in my opinion always felt under powered for what I expect from a 427 so a sticking brake makes sense. What what be a good starting point for me to check on this hub to see why it isn't spinning? I just assume it has to be the brake sticking, I could be wrong and if I am I need help with a direction to go. Thanks for any help.
Pvmt-Pndr #1373254 08/13/2020 11:16 PM
Post pictures of the air brake set up on the backing plate...you could have S-cam or Wedge type brakes and knowing that and might help others help you figure it out...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Pvmt-Pndr #1373255 08/13/2020 11:37 PM
Here you go. Hopefully someone can point me in the right direction and let me know what I have.
Pvmt-Pndr #1373275 08/14/2020 3:49 AM
3B Offline
Hy Pvmt-Pndr, those are either S cam or Flat cam brakes not wedge brakes. See if you can move the top of the slack adjuster towards the front of the truck, if there is any movement there then I doubt that your wheel is being held in place by the brakes. Have you ever adjusted air brakes?
Pvmt-Pndr #1373280 08/14/2020 9:16 AM
Thanks, I'll do that when I get home this evening and report back. I have not adjusted the brakes. I think I have a pretty good idea how to from research on the web, I'll take any helpful hits though.
How does the hub come apart if I need to get into it to do more investigating?
Pvmt-Pndr #1373296 08/14/2020 1:50 PM
3B Offline
Hy Pvmt-Pndr, the hub removal process is the same as a truck equipped with hydraulic brakes, back off the brake adjustment, remove the hub cap, fold back the bearing nut locking tab, remove the wheel bearing adjusting lock nut and adjusting nut, pull off the outer wheel bearing and remove the hub and drum assembly. Air brakes have return springs just like hydraulic brakes and when they break strange things can happen. Wheel bearings can seize and lock the hub up as well, good luck getting things apart.
Pvmt-Pndr #1373521 08/15/2020 9:45 PM
It ended up being the slack adjuster was a little too tight. While I already had it apart I went ahead and inspected the pads and repacked the bearings. Thanks for your help. I found a bad tie rod end while I had my daughter in the cab and I was u set the truck adjusting. Is there a go to place for these truck tie rod ends?
Pvmt-Pndr #1373535 08/15/2020 11:07 PM
3B Offline
Hy Pvmt-Pndr, we will need to know the front axle capacity before we or a parts store can get you the correct tie rod ends. Clean the axle off with a wire brush, you are looking for some casting numbers (raised), most of them that I have found have been near the center of the beam, good luck with the search
Pvmt-Pndr #1373632 08/16/2020 7:53 PM
I found them. They're not clear enough to read. I'll post a picture and maybe someone will be able to narrow it down. I've also posted every other thing I can to try to figure it out. It looks like my springs are 9k pound springs
Pvmt-Pndr #1373634 08/16/2020 8:02 PM
Hopefully this will add to helping also
Pvmt-Pndr #1373665 08/16/2020 10:09 PM
3B Offline
Hy Pvmt-Pndr, okay your truck has a 9000 lb. front axle, the o.e.m. p/ns are right 2330712 left 2330713 I did cross the numbers at Napa's website but I got three possible numbers. So My advice is take the failed part with you to Napa with the part numbers I have given you and see if they can figure out the correct one to bring in for you. Hope that helps.
Pvmt-Pndr #1373673 08/16/2020 10:41 PM
Thank you very much 3B I appreciate your time and energy spent helping me out
